Raspberry Pi Forum Pi 2 - can't SSH from Putty
  • Subscribers 677 subscribers
  • Views 870 views
  • putty
I've just got my new 1Gb pi 2, and although its nice and fast I'm having a problem connecting to it using SSH via Putty. With my other Pis (I've got three of them) its been very straightforward -  I get the IP address (using hostname -I), open up a session in Putty, type in the IP address and I get a session on the Pi.
I can ping the Pi, access webpages on it (I'm running Apache on there) and ftp to it so I cant see it being a connection issue. The error I get is as follows ;
Anyone else having a similar problem?
  • gadget.iom
    gadget.iom over 10 years ago
    Try running raspi-config on the offending Pi and see if SSH is enabled.
  • Problemchild
    Problemchild over 10 years ago
    This was covered last week cant remember the thread now... yes run raspi-config or
    sudo netstat -antp| grep sshd
    and you should see a line not unlike this:
    tcp    0  0 0.0.0.0:22          0.0.0.0:*           LISTEN  1656/sshd
    Former Member over 10 years ago in reply to Problemchild
    Thanks john - I can see sshd running on port 22 but I still get the same error when trying to Putty to it
  • rew
    rew over 10 years ago in reply to Former Member
    Weird problem. It half looks as if your windows-firewall is blocking the connection. How about you try to ssh into the new pi from one of the old ones? If the error message doesn't explain to you what's wrong, consider "ssh -v otherpi" are report here what it prints....
    I have found out that if I restart the ssh service I could at least get the login prompt
    sudo service ssh restart
    Someone suggested checking the permissions so I compared the contents of /etc/ssh on the new Pi, and they are different, so I'm going to try changing these so that they match each other, and then see if that makes a difference.
