Raspberry Pi Forum hdmi r pi
  • Replies 10 replies
  • Subscribers 676 subscribers
  • Views 945 views
  • frontpage
  • raspberry_pi_space
hdmi r pi
I bought r pi and used a hdmi vga converter. Went on display when noobs install and then at the end of the installation of the display is turned off and can never get a view I have tried all the config file. if something burned on r pi? or he hdmi vga converter? or something else ...
Damir
    Still nothing ... I ordered hdmi dvi cable so I'll try to dvi monitor. If someone has a suggestion feel free to speak up. Question is thoes not working hdmi serial converter or I burned r pi hdmi output.
  • gadget.iom
    gadget.iom over 10 years ago in reply to Former Member
    Can you remove the SD card, put it in a computer, open '/boot/config.txt' and uncomment the following lines?
    hdmi_drive=1
    hdmi_force_hotplug=1
    Former Member over 10 years ago in reply to gadget.iom
    Ok thanks I will try that!
    Damir
  • gadget.iom
    Great. Hopefully that helps.
    Let us know how you get on image
    Paul.
    mcb1 over 10 years ago in reply to gadget.iom
    I think you should be checking your power supply.
    The hdmi was present when you fired it up, and the couple of installs I've done I never had any issue with HDMI not being present ...except in the early days with a power supply dropping below 4.8v?
    There is some trouble shooting information here.
    http://elinux.org/R-Pi_Troubleshooting
    In particular
    http://elinux.org/R-Pi_Troubleshooting#Troubleshooting_power_problems
    Their advice about removing the ethernet and USB during boot is a quick way to see if it is the cause.
    Former Member over 10 years ago in reply to mcb1
    I tried without USB and Ethernet and only with hdmi vga converter and nothing.
    I will try to check the power supply. I think it's okay because the output is 5V 750mA.
    thanks
    Damir
  • gadget.iom
    That would be a wise move. 750mA is cutting it a bit fine. More information about power supply requirements can be found here:
    http://www.raspberrypi.org/help/faqs/#powerReqs
    Oh, it's confusing because the first turn I got the picture. I modified the config file but nothing happen.
    TNX
    Damir
    Former Member over 10 years ago in reply to Former Member
    Here's the info, I successfully installed NOOBS on R Pi seems to be a problem in HDMI VGA Converter. Now I use HDMI DVI cable and it works thanks to everyone.
    TNX
    Damir
  • gadget.iom
    Thanks for the feedback. image
