Raspberry Pi Forum Cirrus Audio, B+, and Jack??
  • Replies 10 replies
  • Subscribers 675 subscribers
  • Views 1293 views
  • pure
  • raspeberry_pi_accessories
  • data
Anyone get jack working with this card on the B+?
With this command:
jackd -P70 -p16 -t2000 -d alsa -dhw:sndrpiwsp -p 128 -n 3 -r 44100 -s &
I get this error:
Copyright 2001-2005 Paul Davis and others.
Copyright 2004-2012 Grame.
jackdmp comes with ABSOLUTELY NO WARRANTY
This is free software, and you are welcome to redistribute it
under certain conditions; see the file COPYING for details
JACK server starting in realtime mode with priority 70
audio_reservation_init
Acquire audio card Audio1
creating alsa driver ... hw:sndrpiwsp|hw:sndrpiwsp|128|3|44100|0|0|nomon|swmeter|soft-mode|32bit
configuring for 44100Hz, period = 128 frames (2.9 ms), buffer = 3 periods
ALSA: mmap-based access is not possible for the capture stream of this audio interface
ALSA: cannot configure capture channel
Cannot initialize driver
JackServer::Open failed with -1
Failed to open server
I'm ultimately trying to get this working realtime with Pure Data.
Thanks!!
    Hi
    I get the same error with a Raspberry Pi B and Wolfson Audio Card. I'm trying to use jackd to use it with Guitarix and Rakarrack.
    BR / Fernando
    Former Member over 10 years ago in reply to Former Member
    Here's something that may be relevant:
    https://github.com/raspberrypi/linux/commit/bad49c21520ddc40d512a0d424cbc94f20068e6c
    As specified on the linux audio wiki (http://wiki.linuxaudio.org/wiki/raspberrypi#using_jack), Jack needs to be patched in order to work correctly, however I did reinstall it from those repositories and haven't really gotten any further.
    As far as the code supplied by the first link, can anyone give me pointers on how to build/install that?
    Thanks.
    I have seen the same error with jack. ALSA's dmix and dsnoop plugins don't work either, they also complain over no mmap in the hardware driver.
    It all works on my B Pis with Wolfson cards and the old 3.10 kernel.
    Somewhat relevant, that is the commit that added memory mapped I/O support to the Pi's built-in audio.
    It lead me on the right path, though. I looked over the kernel source tree from Cirrus Logic, comparing it with the old 3.10 kernel for the Wolfson card.
    I found a regression in sound/soc/bcm/bcm2708-i2s.c. Memory mapped I/O for i2s has disappeared in their 3.12 kernel.
    I have patched the source and built a kernel which works on my B+ with a Cirrus Logic card.
    The kernel can be downloaded from here:
    https://drive.google.com/file/d/0BzIaxMH3N5O1Z0dUWjRDVktUbjQ/view?usp=sharing
    File name is kernel_3_12_33_cl_mmap.tgz
    Size is 16MB
    md5sum: ca492de7f00cc214ccd40baf7f8288ff
    The archive contains:
    boot/kernel_cirrus_mmap.img          # The kernel.
    lib/modules/3.12.33_CL_MMAP          # ... with many subdirectories. Kernel modules.
    The archive doesn't overwrite your current kernel or modules.
    To install:
    • Become root: sudo -s
    • Go to root directory: cd /
    • Untar the archive: tar xvzf /path/to/where/you/saved/kernel_3_12_33_cl_mmap.tgz
    • Add the line
        kernel=kernel_cirrus_mmap.img
      to the file /boot/config.txt
    • Reboot
    If it doesn't work, you can revert to your original kernel by just removing the "kernel=kernel_cirrus_mmap.img" line from /boot/config.txt
    For those of you that build your own kernels, I've attached a patch file with my changes.
    Ragnar
    cirrus_logic_mmap.patch.zip
    Thanks for the patch. I have built a new deb package for the kernel with your patch. If you like I can put it on https://blog.georgmill.de/2015/02/18/update-for-wolfson-audio-card-on-raspberry-pi/ .
    Have fun.
    Georg
    If you like and can put it on https://blog.georgmill.de/2015/02/18/update-for-wolfson-audio-card-on-raspberry-pi/ ,too.
    I have some difficulties parsing that sentence, but I think my answer is "yes" image
    Ragnar
    Here you are :linux-image-3.12.33-georg_2_armhf.deb
    Works OK, both Jack and the ALSA plugins. image
    On your website:
    the Pi’s built-in audio
    should be
    the Wolfson/Cirrus card
    or something to that effect. The Pi's builtin audio has had mmap support since 2013, but it was that patch that led me onto the right track.
    Ragnar
    Ooops, you are right. Updated the website. Thanks.
    Have fun
    Georg
    Hi, thanks a lot for your help. I have installed the patch and configured everything but I did not have the time to test it.
    I'll post a message with the result.
    Georg, another correction for your blog:
    sudo nano /etc/modules/ should be sudo nano /etc/modules
    Best regards / Fernando
    Thanks for that hint. Updated website some minutes ago
    Best regards
    Georg
