Raspberry Pi Forum Cirrus Logic Audio Card working on the Raspberry Pi 2
  • Replies 165 replies
  • Subscribers 715 subscribers
  • Views 27030 views
  • wolfson
  • raspberry
  • audio
  • pi
  • cirrus
  • rpi2
  • raspeberry_pi_accessories
  • pi2
Hi all!
As you might know, Cirrus Logic's main kernel source branch recently switched to 3.18.
My first thought was "Hmm, that means the Cirrus Logic card could finally work on the RPi2..."
I have built a couple of 3.18 kernels for my B+ and RPi2 and I have managed to get both models to produce sound image
It's still early days, i.e. there are possibly bugs and glitches to fix, but for those of you who would like to try it out I've made an image file that you can download here:
https://drive.google.com/file/d/0BzIaxMH3N5O1cmJ1bFhMcG1hc0E/view?usp=sharing
The file is a 1.3 GB zip. Uncompressed size is 3.1 GB, so it fits comfortably on a 4 GB card.
The image is based on the standard 2015-02-16-raspbian-wheezy image from the Foundation that you flash to a SD card for a fresh install.
I have only added my kernels and set up the configuration files to get the card going.
It should work on the older B model  with a Wolfson Audio Card too, but I haven't tested that yet.
Have fun!
Ragnar
    e14 Contributor over 11 years ago in reply to e14 Contributor
    Diego Caballero wrote:
    I am making a project about audio recorder with RPi2 and cirrus audio logic card, i wonder if you answer me some questions:
    1) What are the steps to connect RPi2 with Cirrus audio logic card?
    <shameless plug> I just published a blog post which summarizes my research on this particular question https://stmllr.net/blog/cirrus-logic-audio-card-on-raspberry-pi2-with-debian-jessie/index.html
    [edit] Disclaimer: the post requires some experience with linux and patching here and there.
    Do you mean https://packages.debian.org/de/jessie/flash-kernel ?
    Sound good. How can I support you with that?
  • hiassoft
    hiassoft over 11 years ago in reply to e14 Contributor
    Nice post!
    Just a few additions, first the important one: when you compile the kernel by yourself, be sure to copy over all the devicetree files. Most importantly the bcm2709-rpi-2-b.dtb, but also all the other overlay files. These files get important changes from time to time and if you happen to use devicetree files not matching your kernel version you might run into very strange errors - I got caught by this once during testing.
    sudo cp -f arch/arm/boot/dts/*.dtb /boot/
    sudo cp -f arch/arm/boot/dts/overlays/*.dtb arch/arm/boot/dts/overlays/README /boot/overlays/
    And I prefer to use mkknlimg from the RPi kernel tree instead of some external one:
    sudo ./scripts/mkknlimg arch/arm/boot/zImage /boot/kernel7.img
    The rest of your instructions look fine, good job!
    Edit: And, yes, this forum software is a real PITA. Almost every time I have to switch to html mode and edit the html code directly because the "advanced" or "full" editors messed something up...
    so long,
    Hias
    I dont have experiencia with raspberry ...well its better ..that i will buy a raspberry b+?  Or i want to know that un raspberry to is possible? Please i need help urgent!!
    I cant add these line after installing ...please help me i cant alter /boot/config.txt ..please
    Diego, If you are looking for something which works out-of-the-box, I would suggest to look for an alternative audio board. sorry to say that, but I spend quite some time to get cirrus logic up and running.
    e14 Contributor over 11 years ago in reply to hiassoft
    @HiassofT Thanks for your feedback on the blog post, I added your suggestions.
    ragnar.jensen
    I have followed yours step, i have raspbian 3.18 , and i have installed :
    To install:
    Become root: sudo -s
    Go to root directory: cd /
    Untar the archive: tar xvzf /path/to/where/you/saved/kernel_3_18_9_W_CL.tgz
    But when I want modificate there are 2 problems:
    1)  /boot/config.txt , i dont have permission ...to modificate
    2) /etc/modprobe.d/raspi-blacklist.conf doesnt exist
    please help me..i need to solve this problem..its for my university project , i dont have much time
    Hi Steffen, yes, that's the one. If I got something packaged it would be great if you could do some testing.
    e14 Contributor over 10 years ago in reply to e14 Contributor
    ragnar.jensen
    Thanks i followed your first post and my cirrus audio logic card can connect with PI2, one question , i want to recorder audio in the best quality for maybe 1 hour...and save in de SD card of the RPI2 files .wav , programming in python is a option?  do you have any suggestion about that?
    Can someone help me out?
    please
