Raspberry Pi Forum Cirrus Logic Audio Card working on the Raspberry Pi 2
  • Replies 165 replies
  • Subscribers 715 subscribers
  • Views 27070 views
  • wolfson
  • raspberry
  • audio
  • pi
  • cirrus
  • rpi2
  • raspeberry_pi_accessories
  • pi2
Hi all!
As you might know, Cirrus Logic's main kernel source branch recently switched to 3.18.
My first thought was "Hmm, that means the Cirrus Logic card could finally work on the RPi2..."
I have built a couple of 3.18 kernels for my B+ and RPi2 and I have managed to get both models to produce sound image
It's still early days, i.e. there are possibly bugs and glitches to fix, but for those of you who would like to try it out I've made an image file that you can download here:
https://drive.google.com/file/d/0BzIaxMH3N5O1cmJ1bFhMcG1hc0E/view?usp=sharing
The file is a 1.3 GB zip. Uncompressed size is 3.1 GB, so it fits comfortably on a 4 GB card.
The image is based on the standard 2015-02-16-raspbian-wheezy image from the Foundation that you flash to a SD card for a fresh install.
I have only added my kernels and set up the configuration files to get the card going.
It should work on the older B model  with a Wolfson Audio Card too, but I haven't tested that yet.
Have fun!
Ragnar
    e14 Contributor over 10 years ago in reply to e14 Contributor
    Look in the manual you can download here at this site. There you will find which expansion-pin is equal to the raspberry pin. You have to start with counting with the pins near the speaker holes.
  • clarkman
    clarkman over 10 years ago
    Hey Ragnar!
    We are on Beaglebone Black.  I figure I can learn on my RPi and try then on BBB.  We have two kernels 4.4, and 3.18 (Cirrus), both built with yocto.  Just a couple of questions (thanks in advance):
    1. mainline 4.4 from kernel.org has 2012 version of Cirrus 5102 driver,  3.18 (Cirrus) has the 2014 code.  I count 5 more exported symbols in 2014 code.  Do you know of any Cirrus 3.18 on BBB?
    2. We need to set up a very specific TDM config, 4-6x48k channels into (hopefully) one out, AIFS1, then into McASP.  Do you believe that amixer can handle it, or do we need to write custom i2c code?
    3. Do you have any recommended threads that might show us details we need to make the port?
    THANK YOU
    Clarkman
  • librears
    librears over 10 years ago in reply to clarkman
    Hey,
    did you succeeded? I'm also very interested in accessing more than the standard sterio output channels. Have you found https://www.element14.com/community/message/153021/l/re-cirrus-logic-audio-card-raspberry-pi-2-jack-mono-ports#153021 ?
    Hi All!
    First of all, thanks Ragnar for your great work about the cirrus card, i have been using your image for a year ago,
    and its awsome, til now..something happened and the analogue signal at lineout is distorted and noise
    (seems like just the s/pdif signal is coming, but i hear the audio signal too..)i have tried with openelec and various other distros,
    but the result is the same:( Dont know what to do.  I already try to play a wav with aplay and the result is the same.
    Tried reset mixer settings with script and reenable linout..same result.
    Also tried to remove Spdif out line from udev rules on openelec distro..same ***:(
    Please help!
    Thx,
    p.
    e14 Contributor over 9 years ago in reply to e14 Contributor
    Hello All I have a question/problem..
    I am running the Cirrus Logic Audio Card with a Raspberry Pi 2b
    I want to use the rpi as a digital filter. Therefore I use pyaudio to open a stream and within the callback function to filter.
    Right now I have the problem that after around 5 seconds I get an "ALSA underrun occured" error, could you imagine how this is possible? Or how do I create this error? Checked it with an audio analyzer (at my university) the filtering works but only for a few seconds...
    Trying to google underrun occured raspberry didnt bring up any clues...
