Raspberry Pi Forum Cirrus Logic Audio Card working on the Raspberry Pi 2
  • Replies 165 replies
  • Subscribers 715 subscribers
  • Views 26919 views
  • wolfson
  • raspberry
  • audio
  • pi
  • cirrus
  • rpi2
  • raspeberry_pi_accessories
  • pi2
Hi all!
As you might know, Cirrus Logic's main kernel source branch recently switched to 3.18.
My first thought was "Hmm, that means the Cirrus Logic card could finally work on the RPi2..."
I have built a couple of 3.18 kernels for my B+ and RPi2 and I have managed to get both models to produce sound image
It's still early days, i.e. there are possibly bugs and glitches to fix, but for those of you who would like to try it out I've made an image file that you can download here:
https://drive.google.com/file/d/0BzIaxMH3N5O1cmJ1bFhMcG1hc0E/view?usp=sharing
The file is a 1.3 GB zip. Uncompressed size is 3.1 GB, so it fits comfortably on a 4 GB card.
The image is based on the standard 2015-02-16-raspbian-wheezy image from the Foundation that you flash to a SD card for a fresh install.
I have only added my kernels and set up the configuration files to get the card going.
It should work on the older B model  with a Wolfson Audio Card too, but I haven't tested that yet.
Have fun!
Ragnar
    e14 Contributor over 11 years ago in reply to e14 Contributor
    You're probably crazy image
    At the moment i have
    kernel=vmlinuz-3.18.9-v7cludlmmapfll
    in config.txt on a RPi2, and that's the kernel it boots.
    Ragnar
    yes i am image 'cause, i just made another try and, hum, it works image
    Could you send an MD5 check-sum of the Google doc file? I get all kinds of boot errors (device not ready, etc) and it does not finishes booting.
    For "2015-02-16-raspbian-wheezyW_CL.img" I have 43e14299121e873660883f06a6560b00
    Your 43e14299121e873660883f06a6560b00  md5 sum is correct.
    Ragnar
    I did get it working, had an issue with Win32DiskImage dismounting the SD card. All is well and I am recording audio.
    Thank you so much for this.
    Still very disappointed with vendor for selling me a solution they knew did not work. RPi 2 + Cirrus board.
  • clem57
    clem57 over 11 years ago
    For anyone needing software for cirrus, please read this blog http://www.element14.com/community/message/145775/l/minimal-image-for-pi2#145775
    Clem
    Ragnar:
    Success!!! On my RPI2, I had to use this kernel=kernel7_CL.img, otherwise, it would not boot.  After installing MPC and MPD, and withing MPD, I had left the default for audio output.  By your kernel works 100%!!!!! Thank you.
    Ahmed
    Ragnar,
    the kernel you compile from the CL repository works perfectly with RuneAudio 0.4
    If somebody is interested, just need to blacklist the module snd_bcm2835 with something like this:
    echo "blacklist snd_bcm2835" >> /etc/modprobe.d/blacklist.conf
    and reboot to be sure the CL card is the default one.
    Then, manually config the wifi (wifi-menu, and manually editing the wpa-supplicant) 'cause there is a bug in RA v0.4, and enjoy ! image
    That really sounds great!
    does this also work with the older Rasoberry Pis and the older Wolfson card?
    Thanks, Thomas
    Yes, it works with the older cards too.
    Ragnar
