Raspberry Pi Forum ChipKit Pi wont work.
  • Subscribers 691 subscribers
  • Views 481 views
  • chipkit-pi
  • pi
  • chipkit
  • raspberrypi
  • raspeberry_pi_accessories
I need help getting this device to work on any system. Windows, Linux, Rasberry Pi.. you choose, I just want the damn thing to work on something.
I am trying to use the ChipKit Pi with a raspberry pi2 currently, the error I get is this:
pic32-g++: error trying to exec 'cc1plus': execvp: No such file or directory
I have the board set as chipkit>ChipKit Pi
I have no options for the serial port.
the user is a member of dialout, and may run as root.
when i try to run the analog read example it tells me avrdude was compiled without usb support. ... which I mean who cares, Im not using the USB support, Im using the pin header, and avr-dude isnt even listed as a dependency so GTFO chipKit Pi.
    The error indicates you might be missing some packages? Is gcc-avr installed? (librxtx-java should also be installed).
    Regarding serial connection - MPIDE expects /dev/ttyS0, but it's actually /dev/ttyAMA0. You can create a hard link like so:
      ln /dev/ttyAMA0 /dev/ttyS0
    ...you should then find an option in the serial out selection list :--)
    Have a look at this thread to find an init script that fixes this on each boot (if you use it, remember to chmod +x): Install MPIDE on raspbian - chipKIT.net
