Raspberry Pi Forum config.txt no longer exists?
  • Subscribers 704 subscribers
  • Views 1272 views
I received my AP 2B days ago, and then purchased the Pi NIOR camera, expect to enable it through the raspi-config. But was remind that "firmware appears to be out of data (no start_x.elf), please update". Then I searched the whole file system, (find / -name start_x.elf -print), could not find it. And also I could not see any config.txt file under /boot either.
Is config.txt no longer there?
  • clem57
    0 clem57 over 11 years ago
    Look around 448 in http://pastebin.com/tfp4chFQ for what is tested for camera. So I have berry boot and they add a start for same https://github.com/maxnet/berryboot/issues/82. You need to start also.
  • cstanton
    0 cstanton over 11 years ago
    Assuming that you're running Raspbian and that you're able to get to a terminal, why not just run:
    sudo rpi-update
    And see if that fixes your out of date problem?
