Raspberry Pi Forum Videos bei Ubuntu MATE ruckeln!?
  • Replies 13 replies
  • Subscribers 704 subscribers
  • Views 2577 views
  • videos
  • raspberry_pi_space
  • ruckeln
Hallo Leute,
ich hab bei meinem Raspberry PI 2 Ubuntu MATE geladen und habe bemerkt, daß Videos über Youtube nicht fließend bis überhaupt nicht laufen. Meines Erachtens liegt das an der Grafikeinstellung.
Habe schon versucht in der config.txt den Raspberry zu übertakten und den GPU-Speicher zu erhöhen, aber ohne Erfolg.
Gib es sonst irgendwo Einstellungen die man beachten muss, oder muss man eine Zusatzsoftware installieren. Bin nicht unbedingt ein Ubuntu Profi und neu in der Raspberry Welt.
Wäre Super wenn mir jemand weiterhelfen kann.
THX
Benny
  • clem57
    0 clem57 over 11 years ago
         Here is the same as you http://www.linuxlinks.com/article/20150322045655702/UbuntuMATE1504-Software.html Could you try XFCE instead of MATE? I did se this which may explain your http://askubuntu.com/questions/654945/ubuntu-raspberry-pi-2 sugesting Raspian for suport of GPU video.
    C
    0 balearicdynamics over 11 years ago
    I suggest that we all use english, good or bad, as not all know Spanish, German, Italian, French (just to cite the languages that periodically appear in some posts) ...
    Thank you. Enrico
    0 Jan Cumps over 11 years ago in reply to balearicdynamics
    It's part of e14 ecosystem that you can post in your own language and indicate on the post what language it is. There's a selection box for that.
    There's even an area where there's a weekly give-away for German posts. I think it's the cadsoft/eagle one, but not entirely sure.
    0 Jan Cumps over 11 years ago in reply to Jan Cumps
    It was here:
    http://www.element14.com/community/message/37387/l/re-hier-k%C3%B6nnen-sie-ihr-design-und-anwendung-in-deutsch-eingeben-…
    0 balearicdynamics over 11 years ago in reply to Jan Cumps
    I see but at least something in english gives better audience. Else the posts are condemned to remain unread by many users that can be very helpful.
    Enrico
    0 e14 Contributor over 11 years ago in reply to balearicdynamics
    Ciao Enrico,
    ti scrivo mi messaggio in italiano. Ho installato Ubuntu MATE sul mio Rasdpbery PI 2 e ho notato, che i filmini su Youtube vanno molto male, vuol dire che il film va a tratti come se la memoria della GPU non si sufficiente.
    Ho gia alzato la potenza sotto conig.txt e anche la memoria del GPU. C'è da installare un ulteriore APP o driver. P.S. Sono nuovo nel mondo di Raspberry e Ubunto.
    È consigliabile di usare il Raspian, perché dovrei usare il Raspberry come un tipo presentatore dove vengono presentati diversi siti internet dove può succedere che vengono illustrati anche filmini tramite Youtube.
    Grazie della collaborazione.
    Benny
    0 balearicdynamics over 11 years ago in reply to e14 Contributor
    Ciao Benny, Posso risponderti in inglese? Scusa ma il tedesco é veramente una lingua che conosco davvero a stento image
    Penso di poterti dare qualche suggerimento.
    Enrico
    se mi rispondi in italiano per me è meglio, perché il mio inglese non è al 100%image, perché sono di Bolzano
    Grazie mille
    Ok, come ti hanno giá suggerito forse Raspian é la cosa migliore, per quanto riguarda la gestione della GPU. Questo perché si tratta di una distribuzione di Debian specifica per Raspberry (come anche Ubuntu é cugino di Debian per cui condivide molte altre cose). Per quanto riguarda la mia personale esperienza ti devo dire che Ubuntu, nella sua semplificazione dell'interfaccia, per quanto abbiano fatto un buon lavoro é comunque piú pesante di Debian che - ovviamente - possiede un'nterfaccia piú "povera" pensando all'utilizzatore.
    Leggo che tu devi utilizzare il PI per fare delle presentazioni, per cui alla fine non credo che questo fatto influenzi molto la cosa perché quello che la tua audience vede é lo screen della presentazione e non l'impiego del sistema operativo con una interfaccia desktop piú o meno "evoluta".
    Ci sono alcuni aspetti che dovrebbero essere approfonditi a mio avviso. Ti riassumo qui alcune domande che io mi porrei prima di tutto:
    1. Hai verificato, magari con un altro sistema in parallelo, anche uno smartphone, che la banda di cui disponi per vedere i filmati su youtube sia effettivamente sufficiente?
    2. La connessione di rete utilizza la WiFi (quindi un dongle esterno) oppure la connessione standard ethernet del Raspberry? Nel caso utilizzi la wifi, hai provato a verificare se esiste una differenza visualizzando gli stessi filmati con la connessione di rete via LAN?
    3. I filmati immagino li visualizzi con il browser. In questo caso, stai utilizzando Firefox / Mozilla? Su Raspbian il browser "di serie" a mio avviso (e non solo mio) é abbastanza limitato, ma funziona bene ed é abbastanza leggero Chromium, ovvero la versione di Chrome con cui ho visto che viene supportato quasi tutto.
    Questo prima di affrontare il noioso compito di creare una nuova installazione di un sistema operativo diverso che é sempre una lungaggine specialmente se si puó evitare.
    Adesso ti faccio un test video e poi lo pubblico e vediamo che succede con un raspberry PI 2
    Enrico
    Il PI è collegato alla rete LAN e abbiamo una Banda di ca. 15 Mbps down e 1 Mbps up. La banda è sicuramente abbastanza.
    Uso il Chromium, perché il Firefox non integra il flash.
    Ti giro un link che dovrei usare:
    http://seis.it-wms.com/wmspanoviewer.php?lang=de
