Raspberry Pi Forum How to control 2 audio Inputs
  • Subscribers 706 subscribers
  • Views 767 views
  • raspeberry_pi_accessories
Hi I am a newbie at this so just know I am learning from scratch.  I own a Raspberry Pi 2.  I know the Pi 2 has only 1 output but no inputs.  I want to use the wofson on the pi2 like a audio switch. I want to have 2 separate inputs coming in at once, One would play at a time of course, then switch 1 on at a time going out on the output plug to the amp.  Can I do this remotely and be able to control the volume too?
  • artful_bodger
    0 artful_bodger over 10 years ago
    Do you intend to do something with the signals inside the pi? If not, you could use a relay controlled by the pi to swap the 2 analogue signals over.
    No volume control though.
    A USB soundcard would probably be the simplest route as it will give you a second audio input (when added to the audio input of the Wolfson card) to allow you to switch between the two.
  • amgalbu
    0 amgalbu over 10 years ago
    Hi
    you probably need a simple circuit with an analog multiplexer controlled by a Raspberry GPIO
    Regarding the remote control there is plenty of resource on the net. I like this tutorial from adafruit
    https://learn.adafruit.com/using-an-ir-remote-with-a-raspberry-pi-media-center/overview
    Cheers
    Ambrogio
