Raspberry Pi Forum PIFACERELAYPLUS
  • Replies 22 replies
  • Subscribers 708 subscribers
  • Views 4059 views
PIFACERELAYPLUS
I hope you can help, I am sure that my question is really easy to resolve but first I think a little introduction .
I am recently retired and looking for a pastime, I remembered the fun I had with our two children making robots using Technik Lego, Sinclair Spectrum and an interface box called “ROBOTECH”
I decided to buy a Raspberry Pi and have started learning Python3, I do not find it easy to learn, from a book only, so thought I would add the PI Face Relay+ to give me the same inputs and outputs as I had on the Spectrum.
I downloaded the PiFace “Getting started “ and started to run through the spec and to run the setup procedure, it was only after several hours of frustration that I happened upon other instructions for other Piface products which lead me to load other software and to configure the Pi. This extra download and config is not mentioned at all in the Piface relay+ “Getting Started”
I am now able to run the Testing and the Example, so far so good.
I now come to my problem, no where can I find instructions as to how to use the GPIO pins on the PiFacerelayplus board.
I only need a nudge in the right direction, but at the present time I am lost.
  • gadget.iom
    0 gadget.iom over 10 years ago
    Is this of any use?
    Welcome to PiFace Relay Plus’s documentation! — PiFace Relay Plus 0.2.2 documentation
    0 e14 Contributor over 10 years ago in reply to gadget.iom
    Hi Paul, thanks for your prompt reply, I have seen and looked through the document that you mentioned but I can't see where it gives any info about how to access the GPIO pins on the Pifacerelay+
    I must admit I am quite new to this so the language used may not be as I expected  so I am missing the point.
    Just a simple way to get a switch to turn on a relay is all I need for now.
  • gadget.iom
    0 gadget.iom over 10 years ago in reply to e14 Contributor
    There is a section in the linked document called 'Basic Usage'
    Examples — PiFace Relay Plus 0.2.2 documentation
  • gadget.iom
    0 gadget.iom over 10 years ago in reply to gadget.iom
    There is also a page on here dedicated to the PiFace Relay Plus:
    http://www.element14.com/community/docs/DOC-70583/l/piface-relay-plus-for-raspberry-pi-model-b-plus
    And contained in that page is a PDF getting started guide:
    Getting Started - PiFaceTm Relay+ interface board for Raspberry PiRegistered
    Hi Paul, I very much appreciate you taking the trouble to try to help me.
    I have printed off the Getting started and have managed to run, successfully, the Testing" and the example Python program these both test and use the relays.
    I have also saved and tried to work through the PDF doc you mention, again working with the relays is no problem, but getting to grips with the input side has me stumped so far.
    Before purchasing the Pifacerelay+  I had got to grips with the basics of the GPIO on the Pi and had made some simple circuits using a LED, switch and "Pull up resistor)
    In the tech spec of the Pifacerelay+ it mentions 4 GPIOs with switchable pullups, its this part which has me stumped.
    If you can't help can you make any suggestions where else I might look.
    Garry
    Yes it is what I am referring too.
    I am starting to wonder if I have purchased the wrong board, maybe I need something else.
    If you are able to help it would be appreciated.
  • 1234jgs
    0 1234jgs over 10 years ago in reply to e14 Contributor
    Okay now I feel like an idiot, I thought the PiFace Relay+ was a EXTRA but it's the actual board.
    import pifacerelayplus
    pfr = pifacerelayplus.PiFaceRelayPlus(pifacerelayplus.RELAY)
    pfr.x_pins[0].value <--- The gpio pins are the x pins and are numbered [0] threw [3], this gets the pins value.
    The documentation says that when connected to ground the pin value will be 1.
    bin(pfr.x_port.value) <--- The internet says that this will turn on the fourth pin.
    I don't know why the fourth pin but I'm guessing that something like bin(pfr.x_port[0].value) would turn on the first pin.
    I will post more if I find more, hope this helps and sorry for the confusion.
    0 e14 Contributor over 10 years ago in reply to 1234jgs
    Thanks for your help so far.
    I'm still not clear how I connect an input, say a switch or what ever.
    Garry
  • 1234jgs
    I would connect a gpio pin to a switch that would split off and have one side go to ground. Then have the program compare the value of pfr.x_pins[0].value with 1 and if the result is true the switch is on, if the result is false the switch is off.
  • danringer
    0 danringer over 10 years ago
    isn't the piface relay board triggered by the default rpi gpio pins?  they can be controlled with rip.gpio from python3 or with gordons wiring pi from bash or any shell for that matter.
    https://pypi.python.org/pypi/RPi.GPIO
    https://projects.drogon.net/raspberry-pi/gpio-examples/tux-crossing/gpio-examples-1-a-single-led/
