Raspberry Pi Forum PIFACERELAYPLUS
  • Replies 22 replies
  • Subscribers 708 subscribers
  • Views 4080 views
PIFACERELAYPLUS
I hope you can help, I am sure that my question is really easy to resolve but first I think a little introduction .
I am recently retired and looking for a pastime, I remembered the fun I had with our two children making robots using Technik Lego, Sinclair Spectrum and an interface box called “ROBOTECH”
I decided to buy a Raspberry Pi and have started learning Python3, I do not find it easy to learn, from a book only, so thought I would add the PI Face Relay+ to give me the same inputs and outputs as I had on the Spectrum.
I downloaded the PiFace “Getting started “ and started to run through the spec and to run the setup procedure, it was only after several hours of frustration that I happened upon other instructions for other Piface products which lead me to load other software and to configure the Pi. This extra download and config is not mentioned at all in the Piface relay+ “Getting Started”
I am now able to run the Testing and the Example, so far so good.
I now come to my problem, no where can I find instructions as to how to use the GPIO pins on the PiFacerelayplus board.
I only need a nudge in the right direction, but at the present time I am lost.
    0 e14 Contributor over 10 years ago in reply to Robert Peter Oakes
    Hi Garry,
    I wondered if you could enlighten me as to what these extra downloads and configs are? I have Raspian (Jessie) installed, and have performed a sudo apt-get update, a sudo apt-get upgrade, and have run sudo apt-get install python3-pifacerelayplus. I have also enabled SPI in raspiconfig. However, whenever I try to run the 'blink.py' example, I get an error saying that 'no pifacerelayplus board detected'. Is this what you got before you installed the extra packages?
    Thank you in hope
