Raspberry Pi Forum Pi Microscopes?
  • Replies 11 replies
  • Answers 2 answers
  • Subscribers 706 subscribers
  • Views 2127 views
Pi Microscopes?
Workshopshed
Workshopshed over 10 years ago
Does anyone know of any USB Microscopes that work with the Raspberry Pi?
    0 balearicdynamics over 10 years ago
    Hello Andy, I have published a couple of post. A USB microscope is just used in Meditech as one of the components for skin analisys
    Meditech: Microscope probe preview
    The product is this: Dnt DigiMicro 2.0 Scale - Microscopio digital: Amazon.es: Electrónica
    Enrico
  • Problemchild
    0 Problemchild over 10 years ago
    They almost all do generally they appear as a UVC class device
    I have one of these like a mate of mine shown here:
    0 balearicdynamics over 10 years ago in reply to Problemchild
    The form factor is mostly influenced by the final usage Andy need.
    Instead seeing the video you posted, I have also one just similar to the link I posted on Amazon above; this is a Chinese one and as first try I bought it about one year ago. External aspect is the same but it costs about 15$ while the one I used for Meditech costs about three times. And the difference is in the image quality, availability of technical information, stability, drivers etc. Usually when I search for this kind of products, I buy the cheaper to see what it is in my hands then the better average is - at least until now - the products that Amazon distributes as premium (Amazon prime in USA if I am not wrong). They have tested the product and grant for it. And if I disllike the product I can return it with full refund.
    At least this is my personal experience.
  • Workshopshed
    0 Workshopshed over 10 years ago
    There's a few people who've adapted the Pi Cam to this task too, some of the mechanics are overkill but the 3D printed tube + lens has possibilities.
    http://openlabtools.eng.cam.ac.uk/presentations/2013_08_RPiWorkshop/OLT_MicroscopePresentation.pdf
    OpenLabTools
    Raspberry Picroscope
    The Kitware Blog - 3D Printing Adapter to fit Raspberry Pi Camera to Microscope
  • Problemchild
    what use are you putting the microscope to Andy ?
  • Workshopshed
    0 Workshopshed over 10 years ago in reply to Problemchild
    Likely to be used around the workshop or inspection so want something fairly robust that does not need a laptop to run it.
  • Problemchild
    0 Problemchild over 10 years ago in reply to Workshopshed
    The camera I showed you comes on a stage, a bed for the board been inspected and the right optics for the job where you get good magnification and can run the camera several inches from the work so you can solder or probe underneath it!
    My suggestion is one of these and use a simple HDMI monitor with no computer required or you can go to a USB based solution as already mentioned, same cam does the lot !
  • Problemchild
    0 Problemchild over 10 years ago in reply to Problemchild
    The whole thing runs from under £180 to £320 depending on the config ... Don't think you need that much in reality mine was £ 214 for the staging and a 14MP 1080p video camera!
    0 michaelkellett over 10 years ago in reply to Problemchild
    Where did you get the bits from ?
  • Problemchild
    0 Problemchild over 10 years ago in reply to michaelkellett
    EBAY there's a load of varieties, both myself and James got ours from a seller called Lapsun, we had t o do a software upgrade to get rid of a bug but the cam was good
    http://http://www.ebay.co.uk/sch/i.html?_odkw=inspection+camera&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR2.TRC1.A0.H0.Xinspection+microscope.TRS0&_nkw=inspection+microscope&_sacat=0
