Raspberry Pi Forum Pi OpenCv and usb Webcam Question
  • Replies 7 replies
  • Subscribers 708 subscribers
  • Views 1709 views
m.ratcliffe
m.ratcliffe over 10 years ago
Any help on this idea would be greatly appreciated, I have found a weird issue with integrating a USB webcam with a Pi and open CV.
If I request a snap shot from the webcam it gives me a old one, i'm assuming this is a shot from the start of a frame buffer because if I "burn" a few shots first it gives me a much newer less lagging image. [essentially I ask it for images 6 times and only accept the last one]
OpenCv install I used:
Animated_Grim Blog:3 - Raspbery Pi and OpenCv the Easy Way
Webcam :
Logitech C270 but I get the same issue with a cheap generic ebay one.
Pi:
Model 2
I have been using this work around to get upto date images from the usb webcam, but now I have time I would like to find the root issue and speed my loop up considerably.
Header 1
#!/usr/bin/python
import cv2
cap = cv2.VideoCapture(0)
while(1):
    _,frame = cap.read()
    #Display the first image captured
    cv2.imshow('Camera_LAG',frame)
    #Display the 6th image captured
    cv2.imshow('NO_LAG',frame)
##***Checks If User Has Asked to Leave
    if cv2.waitKey(33)== 27:
        break
##************** Clean up everything before leaving *****************##
cap.release()
cv2.destroyAllWindows()
Does anyone have any idea why this is happening, can I somehow request the newest image from the camera because I would like to speed my image processing projects up.
Mike
  • m.ratcliffe
    0 m.ratcliffe over 10 years ago
    Bump
  • gadget.iom
    0 gadget.iom over 10 years ago in reply to m.ratcliffe
    I have no experience with OpenCV, but is the following article of any use?
    http://stackoverflow.com/questions/24370725/opencv-videocapture-only-updates-after-5-reads
  • Problemchild
    0 Problemchild over 10 years ago in reply to gadget.iom
    So essentially what it's saying is have a seperate thread that is consuming the video frames and that hands you the frames to be processed by this guy's OpenCv prog.
    Cool
    think and do
  • m.ratcliffe
    0 m.ratcliffe over 10 years ago in reply to e14 Contributor
    Thanks for the link Paul, I had come across it in the past but didnt quite understand what the answer was saying.
    John is your reply a dumbed down version of the link paul provided? I hope it is because I understand that explanation quite well, Is this a easy to implement solution?
  • Problemchild
    0 Problemchild over 10 years ago in reply to m.ratcliffe
    Wouldn't say it  was "dumbed down" maybe paired down image
    Any way yes that was what I was on about.
    I wonder if there is some buffer mechanism which needs to be refilled with in V4L or some such and takinga single frame and stoping for processing effectively is jamming up the buffer and you need to purge it to get a new frame. I know some of the security programs have similar problems ...All conjecture though!
  • m.ratcliffe
    0 m.ratcliffe over 10 years ago in reply to Problemchild
    Thanks John, I just re read the link. It made much more sense after your summary.
