Raspberry Pi Forum element14 Wi-Pi
  • Replies 9 replies
  • Subscribers 707 subscribers
  • Views 1144 views
element14 Wi-Pi
tangerineomega
tangerineomega over 10 years ago
I have just bought the element14 WiPi USB stick for use on my Pi 2.
So far, I have fallen at the first hurdle because plugging it in to one of my USB slots, does absolutely nothing.
The instructions suggest entering graphics mode (I assume that is the normal Pi desktop with the raspberry picture in the middle) and double clicking on WiFi config.
That is where I struggle because I do not have such an icon.
Any help would be appreciated.
    0 shabaz over 10 years ago
    Hi David,
    Type in 'lsusb' in a command shell and you should see if it has been detected.
    If so, then your desktop environment (with Rasbian or any other distribution) should have a capability somewhere to configure graphically. You may need to search around, or
    try the top-right of the display (I can't recall - I don't use the graphical environment).
    If you can't find the graphical dialog then you could do it from the command shell.
    There probably are instructions for this somewhere via google however I just follow the steps here:
    http://elinux.org/BBBWiFiConfigs
    The steps are at that location are actually written for the BeagleBone Black but it is the same basic procedure for the Raspberry Pi, since it is Linux related, not single board computer (SBC) related.
  • gadget.iom
    0 gadget.iom over 10 years ago
    These instructions may help you get started from the comment line instead if you prefer.
    https://www.raspberrypi.org/documentation/configuration/wireless/wireless-cli.md
    If you want to do it from the desktop, click the menu button, select run, then enter "wpa-gui".
    It sounds like you're using Raspbian.  May I ask if you're using the Jessie or Wheezy distros?
  • tangerineomega
    0 tangerineomega over 10 years ago in reply to e14 Contributor
    Brian
    Sorry, I don't know.  How can I tell.
  • tangerineomega
    0 tangerineomega over 10 years ago in reply to shabaz
    Hi shabaz
    Thank you for your response because typing lsusb did show that the  usb Wi-Fi Dongle had been detected.
    I will follow the link below from Paul because that is specific to the Pi.
    Thanks again.
  • tangerineomega
    0 tangerineomega over 10 years ago in reply to gadget.iom
    Hi Paul
    Thank you very much.  The link is very helpful and the first command 'sudo iwlist wlan0 scan' did a full scan and found my 2 networks.
    I will try the rest of the details from the forum link later.
    (incidentally, selecting menu and then run "wpa-gui", did not work as it returned an error of "failed to execute child process (no such file or directory)" but hopefully the link you provided to the other forum will suffice.
    Thanks again,
  • tangerineomega
    0 tangerineomega over 10 years ago in reply to tangerineomega
    Hi Paul
    Just to confirm that it worked and wi-fi is now working correctly.
    Thanks.
    0 e14 Contributor over 10 years ago in reply to tangerineomega
    Glad you're good-to-go now.
  • gadget.iom
    0 gadget.iom over 10 years ago in reply to tangerineomega
    That's great news! Thanks for the feedback.
    Have fun with the Pi. image
