Raspberry Pi Forum Using USB ports on Rpi 2 as UARTS
  • Subscribers 705 subscribers
  • Views 483 views
  • ask_an_expert
  • raspberry_pi_space
I am new to the community so apologies in advance if this question has been answered.
Ras Pi 2 has a single uart port (pins 8 and 10). Can a USB port on the Ras Pi 2 with an FTDI 232R cable plugged in behave as an additional COM/UART port (i.e. similar to a COM port on Windows OS)?
  • gdstew
    0 gdstew over 10 years ago
    Yes this should work. After plugging it in you should see something like this is the /dev directory by using this command  ls /dev/usb*:
    /dev/ttyUSB0
    You should also be able to see the FTDI USB/serial converter listed using the lsusb command.
