Raspberry Pi Forum the red and green light are working on my raspberry pi 2, but that;s it...
  • Subscribers 705 subscribers
  • Views 690 views
  • pi
no other reaction from the raspberry, any1 had this issue?
it started with the Ethernet hub which stopped working, and now it's turned on(can see the green and red leds in the front) but besides that there is no reaction and nothing happened.
i have this raspberry pi for few months now, till few days ago it all went fine, but now... crash
  • Robert Peter Oakes
    0 Robert Peter Oakes over 10 years ago
    what has changed if anything
    Power Supply
    added new or different devices
    what if anything shows up on the HDMI screen, text, rainbow square, something else
    this will help in diagnosis
    0 e14 Contributor over 10 years ago in reply to Robert Peter Oakes
    Hi Peter,
    couple of days before this issue,my Ethernet hub stopped working... so there was no connection to the internet and i couldn't use it to watch kodi.
    i thought it was the cable, so i used a different 1 which worked with my laptop but no luck. i tried to use a different hub in the router but nothing.
    yesterday i decided to restore the openelec to the default, but still it didnt help the Ethernet issue.
    as last resort i press "shift" when the raspberry pi started so i could reinstall openelec from scratch... it told me that there is no internet connection so it can download more system operations besides raspberian and openelec, but i needed only the openelec 1... few seconds after it started with the installation, an error message appeared and the the connection with my tv got lost.
    i didnt changed any hardware or anything... i even burned the latest noobs(from openelec website) on my sd card but nothing...
    i'm out of ideas image
    0 Robert Peter Oakes over 10 years ago in reply to e14 Contributor
    So I am assuming that noobs installed ok but then was still unable to get internet / network access, is this correct?
    you are correct.
    OK, based on this I have rather limiting sugestions
    1. ensure the USB power at the PI is correct (5.0V +- 5% ish)
    2. remove all other accessories except the screen
    3. power the keyboard / mouse / wifi adapter if any using a seperate powered USB hub
    4. ensure the Ethernet cable and the hub port it is connected in works by plugging in an alternate device (I have seen this before, sometimes HUBs can also get confused with MAC addresses for a short while if a device is unplugged and a different one quickly plugged in, this is more with domestic grade ethernet routers than commercial ones but it can happen, so try rebooting the Ethernet hub too
    if all this fails then I would tend to agree you may have a fried Ethernet Port, If your sure you have never accidently shorted bits of the PCB while powered on etc and the PI is still in warranty, seek an RMA number to get it replaced
    if it is out of warranty then you may need to purchase another one
