Raspberry Pi Forum Touchscreen input driver for Debian/Raspbian
  • Subscribers 707 subscribers
  • Views 1359 views
Hello, do you all make the source code available for your 7" raspberry pi touchscreen?  I and others are am having issues getting it to work with JavaFX.  The driver work inside of X11 applications, but JavaFX is very light, and uses the devices directly, and I am getting this issue:
SEVERE: 746 udevInput.c:1596 lens_input_pointerEvents_handleSync: malformed multi touch event - ignoring
If I cannot solve this I will need to return the device.
-Pete.
  • clem57
    0 clem57 over 10 years ago
    You do not say what you are using but this may work as touch input: https://kivy.org/docs/contribute.html
    Clem
  • element14support
    0 element14support over 10 years ago
    Hello ziupe
    Welcome to the element14 Community, we hope you enjoy it! I will move this over to the Raspberry Pi Accessories area as it is a better fit.
    Thank you,
    Jamie
    0 e14 Contributor over 10 years ago in reply to element14support
    [sorry if this double posts...]
    Cleam,
    Thanks for the quick response;  my apologies for the lack of details.  Here is what I am using:
    •   Raspberry Pi 7” touch display packaged under the name “element14”
    •   Raspberry Pi B running Raspbian Nov. 2015 with updates
    •   Oracle Java 8u65, NetBeans, running the default "Hello World" JavaFX example app you get from creating a new JavaFX project.
    I thought I would try to investigate why JavaFX is seeing the driver data as invalid, and perhaps change the driver to add an option to output in a fashion JavaFX can understand.  Either that or switch to the OpenJDK and see if behavior is different.  I am guessing the place to look is the default driver packaged with Raspbian/Debian?  I found some interesting info on the below sites using cat on the /dev/input/.  I will take a closer look:
      https://www.raspberrypi.org/forums/viewtopic.php?f=108&t=121268
      http://www.jensd.de/wordpress/?p=845
    Also, thanks for the info at kivy, this might prove very handy if failing to find a solution to the issue.
    -Pete.
    (GMT -5)
    Looks like the way to go is OpenJFX:
    • https://www.linkedin.com/pulse/oracle-just-removed-javafx-support-arm-jan-snelders
    • https://www.raspberrypi.org/forums/viewtopic.php?f=81&t=97367&p=678791#p678791
    0 e14 Contributor over 10 years ago in reply to clem57
    Cleam,
    Thanks for the quick response;  my apologies for the lack of details.  I will connect and move the thread to Paul Regan <http://www.element14.com/community/people/psr>.  For the record, here is what I am using:
         https://www.raspberrypi.org/forums/viewtopic.php?f=108&t=121268 <https://www.raspberrypi.org/forums/viewtopic.php?f=108&t=121268>
         http://www.jensd.de/wordpress/?p=845 <http://www.jensd.de/wordpress/?p=845>
    -Pete.
    (GMT -5)
