Raspberry Pi Forum I can not get i2c to operate on new Pi B+
  • Subscribers 708 subscribers
  • Views 1226 views
  • i2c
  • raspberrypi
wadeelmore
wadeelmore over 10 years ago
When I type sudo i2cdetect -y 1 or 0, I get "... No such file or directory"
I have read several articles and posts.
I have enabled i2c in raspi-config
When I type lsmod | grep i2c, 2c_dev and i2c_bcm2708 show.
I have uninstalled and reinstalled python-smbus and i2c-tools.
I have tried it with the device tree on and off.
config.txt contains
   dtparam=i2c_arm=on
   dtparam=i2c1=on
   dtparam=spi=off
   device_tree=
There is no blacklist file
uname -a shows ...raspberrypi2B 3.18.10
My older Pi works fine.  I have noted the in the /dev/ folder on the older Pi, there are files i2c-0 and i2c-1.  These files are not in the /dev/ folder for the B+
Since this is new, I'm not sure a fresh format and reload would help.  A hammer may make me feel better for a short time.  Any other suggestions?
  • clem57
    0 clem57 over 10 years ago
    Just a silly question: did you reboot?
  • wadeelmore
    0 wadeelmore over 10 years ago
    Yes, several times. image
  • mconners
    0 mconners over 10 years ago in reply to wadeelmore
    Did you load the kernel modules?
    i2c-bcm2708
    i2c-dev
    I think you add them to /etc/modules and reboot
    or use modprobe
    Mike
  • mconners
    0 mconners over 10 years ago in reply to mconners
    Oh, I apologize, I see you said they show up when you do lsmod
  • SGarciaV
    0 SGarciaV over 10 years ago
    I will be getting into I2C with the R-Pi soon and have been doing some preliminary research. I found this:
    https://learn.adafruit.com/adafruits-raspberry-pi-lesson-4-gpio-setup/configuring-i2c
    Maybe it might help? Maybe you've already seen it? In any case, good luck!
  • Robert Peter Oakes
    0 Robert Peter Oakes over 10 years ago in reply to SGarciaV
    The links are a help but if your using the latest Raspbian "Jessie" then it is much simpler and these videos / posts are quite a bit out of date
    I am also workig on producing a video to use the PI, Raspbian and Win10IoT with I2C and SPI devices, should be out soon
