Raspberry Pi Forum Pre-installed Noobs
  • Replies 21 replies
  • Subscribers 707 subscribers
  • Views 3944 views
  • issues
Pre-installed Noobs
Today, I received my purchased pre-installed Noobs OS. I get a blank screen when I boot my pi2. I can see the files on the sd card when I insert it nto my PC. Also, I want load a single OS onto a another sd card and safe keep my original copy. Could someone give me some instructions on how I should proceed or what I may be doing wrong. I run Linux OS on my PC. Thanks.
  • clem57
    0 clem57 over 10 years ago
    Carl Wilson
    http://openelec.tv/get-openelec
    is a link to a package for RASPBMC that I use or my media center. Give it a whirl and see what you think.
    Happy user,
    Clem
    0 e14 Contributor over 10 years ago in reply to mconners
    Ok. Yes, I am aware of that link. Just can't get the commands to work. Thanks
    0 e14 Contributor over 10 years ago in reply to clem57
    Hello Clem, thank you for link. I try openelec.tv. Maybe this CL will work: sudo apt-get update && sudo apt-get install openelec.
  • mconners
    0 mconners over 10 years ago in reply to e14 Contributor
    Are you saying you are doing
    sudo sh -c "echo 'deb http://download.opensuse.org/repositories/home:/osmc/xUbuntu_15.10/ /' >> /etc/apt/sources.list.d/osmc-installer.list"
    sudo apt-get update
    sudo apt-get install osmc-installer
    and it's not working?
    Mike
  • mconners
    Or you just can't get NOOBS to install?
    Mike
  • mconners
    Have you tried this
    http://qdosmsq.dunbar-it.co.uk/blog/2013/06/noobs-for-raspberry-pi/
    if you have not done anything to the NOOBS card you received, you may not have to reformat it, it should already be fat 32
    You can just insert it, if the system automatically mounts it, you can just go delete everything off of there and follow the section
    Copy to the SD card
    also your SD card may not be /dev/mmcblk0
    Mike
    I ran those commands when I was following the download instructions from the "link". It did not work properly. Do I type line 1 as is? I will try it again.
    Thank you
    Carl
    I can't get the pre-installed NOOBS to boot/load.
    Carl
    Ok. Great advice. I research those ideas. Thanks.
    Carl
  • Robert Peter Oakes
    0 Robert Peter Oakes over 10 years ago
    Here are a few tutorials I just posted regarding creating and installing Noobs and Raspbian on a PI, Perhaps it may help folks
    Create a BOOT SD Card
    Install Raspbian using NOOBS
    Config WIFI for Raspbian
    Detailed Assembly of the PI 7" LCD
    Testing the 7" LCD
    Installing Raspbian without NOOBS
    I have a bunch of other PI stuff like Node Red etc on my channel too but thats getting off topic, the above is all with the Latest Jessie build Raspbian 1.5.0
    Hope it helps, I will be posting them more formally on E14 site very soon
