Raspberry Pi Forum please help to connect and configure the chipKIT pi
  • Answers 3 answers
  • Subscribers 707 subscribers
  • Views 1125 views
  • raspeberry_pi_accessories
I'm from Russia and I don't know where to Find information on connecting and configuring the ChipKIT Pi to RaspberryPi2, could you explain to me or give links to sites with instructions
  • uscdadnyc
    0 uscdadnyc over 10 years ago
    The ChipKit that you bought has 26 pins on the GPIO (female) Header, while your RaspPi2 has 40 pins on the GPIO (male) Header. You need to Buy two items. One to convert 40 pins to 26 pins. Another to take the female Cable and "turn" into Male, so that your Female Header on your ChipKit can connect.
    First Item:
    Downgrade GPIO Ribbon Cable for Pi A+/B+/Pi 2 - 40p to 26p
    Manufacturer: ADAFRUIT INDUSTRIES
    Newark Part No.: 28Y5154
    Manufacturer Part No 1986
    Second Item:
    Pi Rack for 26pin RaspPi
    Manufacturer: PiFace
    Newark Part # 97W2503
    Manufacturer part no. Pi Rack
    __________
    Be Careful with placement of Ribbon Cable/RaspPi2/Pi Rack/ChipKit. MAKE SURE that Pin 1 on all male/female Headers are all oriented the Same Way.
    Looking at the Lettering printed on your Boards, the Headers will be in the Upper-Left
    BTW (By The Way) I believe the P- Rack is MD (Manufacturer Discontinued), So Buy it while you can.
    USCDADNYC (NY NY USA)
  • clem57
    0 clem57 over 10 years ago
    http://cpc.farnell.com/1/1/201786-piface-i-o-shim-raspberry-pi.html  can be used if you do not mind the card standing on edge and are careful with it,
    Clem
  • uscdadnyc
    0 uscdadnyc over 10 years ago in reply to clem57
    Thx for your contribution. The Pi-Face-SC13561-Shim (Manu-Order Code-Part #) will allow DO to use a Straight 40pin-to-40pin Ribbon Cable INSTEAD of item #1 from my list.
    However I think that the Shim Kit comes w/ ONLY ONE dual-20pin  Right -Angle Male Header. DO will have to buy an additional dual-20pin Male Header, Trim it down to 26pin. Solder both male headers to the Shim PCB.
    I have an old RaspPi w/ 26pin GPIO Header (circa 2013) so I just ordered a Pi-rack for 26pin RaspPi b/f they run-out
    0 e14 Contributor over 10 years ago in reply to uscdadnyc
    thank you so much for your help, I'll definitely buy what you advised me. and while I do so.
    0 e14 Contributor over 10 years ago in reply to clem57
    thank you for your help.
