Raspberry Pi Forum the way of expand rootfs
  • Subscribers 707 subscribers
  • Views 1583 views
  • raspberry pi b
  • expand rootfs
  • wolfson_3.10_master.img
Please tell me the wayt o expand  the way of expand rootfs.
I use the woifson audio card for hi-resolution audio sources.
I installed  "wolfson_3.10_master.img" into my Raspberry pi B board.  I want to expand rootfs to store various hi-resolution audio sources in SD card.
But I could not use expand_rootfs(respi-config) at "wolson_3.10_master.img".
I checked a lot of blogs  to do it.
It seemed popular to delete heidden Linux partion and make new partion and use resizefs2x.
I tried it as below ,but I could not expand rootfs,
(1)I chcked the status of partions by fdisk , p.
        sudo fdisk /dev/mmcblk0
         Command : p
(2)I got the result as below.
(3) I deleted /dev/mmcblk0p6 and made new partions:mmcblk0p4 and mmcblk0p6.
(4) I did "Reboot", but the Kernel was halted during the booting.
(5) I never expanded rootfs.
I'd really appriciate it if anyone tell me the way to expand rootfs.
  • clem57
    0 clem57 over 10 years ago
    yoshiki kato
    Ok I see you did not use contiguous partitions.
    1. Reimage the card with original wolfson_3.10_master.img
    2. print the partitions like above.
    3. create a new partition at the end with a mount point "/audio" as big as you can.
    4. reboot Pi
    5. You now have extra storage in "/audio" to use as you wish.
    Let me know if this works by marking this "correct" or post errors comments otherwise. Use sd card - How can I resize my / (root) partition? - Raspberry Pi Stack Exchange  as a reference only for howto.
    Clem
    0 e14 Contributor over 10 years ago in reply to clem57
    Dear Clem Martins
    Thank you for your advice.
    To make sure, I do some questions?.
    (1) Do I have to make new partion which start from 15415296  by fdisk -n ?
    (2) Do I need to modefy /etc/fstab for new partion?
    I'd really appriciate it if you will give me the detail of proceedures of creating new partion.
  • clem57
    0 clem57 over 10 years ago in reply to e14 Contributor
    yoshiki kato wrote:
    Dear Clem Martins
    1. Yes Linux fdisk command and examples
    2. Yes if you want it to mount on bootup.
    Clem
  • mconners
    0 mconners over 10 years ago
    If you are new at this and are unfamiliar with the fdisk command, you might be better suited using gparted.
    gparted is a graphical partition editor.
    It will show you the unused space on your disk/sd card an allow you to expand it.
    On a debian/raspbian based system, it can be installed using
    sudo apt-get install gparted
    and then you would run it like
    sudo gparted diskdevice
    and example would be
    sudo gparted /dev/mmcblk0
    the web site is here if you need more info.
    Mike
    0 e14 Contributor over 10 years ago in reply to mconners
    Dear Michaael
    Thank you fpr your advice.
    I could make new partition and expand it before getting "gparted".
    But I installed "gparted" into my Raspberry-pi.
    It  is very useful tool !
