Raspberry Pi Forum Analog recording problems on Cirrus Logic Audio Card
  • Subscribers 706 subscribers
  • Views 457 views
  • raspeberry_pi_accessories
Is anyone else having a problem getting sufficient "swing" on the digital data captured from the Cirrus Logic audio card?
I am capturing from Line In, and no matter what I set the various gains to, I can not get digital data greater then
+/- 2940 (decimal), which is certainly less then the expected +/- 32768 that I should be getting in 16 bit mode.
I can certainly get it to distort, but it still "peggs-out" at that value.
Someone please help!!
Thanks.
  • clem57
    0 clem57 over 10 years ago
    Sounds like you need an op amp for the signal before the line in. Can you measure the amplitude of the frequency? A scope would be helpful.
    Clem
    0 e14 Contributor over 10 years ago in reply to clem57
    I am injecting 1KHz at 1V peak to peak (verified on my scope). As I said, I can definitely turn the gain settings up
    and cause distortion, but it still clips at that low digital level.
  • clem57
    0 clem57 over 10 years ago in reply to e14 Contributor
    So this is a test? Usually this adc circuit is a sampling of the wave in this case 1V peak to peak. If the wave is low, you may want to try 2V to see the difference in digital swing.
    Clem
