Raspberry Pi Forum Upgrade/rpi-Update Cirrus Card
  • Replies 9 replies
  • Subscribers 707 subscribers
  • Views 1104 views
  • upgrade/rpi-update cirrus card
  • raspeberry_pi_accessories
hi my friends image
i have use uv4l by my Rpi to stream video and audio to another equipment (PC , Smartphone ..) , so must be used rpi-update because it is an interesting steps to enable the uuv4l but  a rpi –update / upgrade will currently result in the replacement of a kernel, hence audio card support will be lost if this action is completed
    what is the solution of this problem ??? image
  • clem57
    0 clem57 over 10 years ago in reply to e14 Contributor
    Marouenne Ben Ahmed
    Have you created an issue with the author(s)? Most will gladly fix a problem once it is reported.image But never reported would be nothing to fix.
    Clem
    0 e14 Contributor over 10 years ago in reply to clem57
    No but when i use rpi-update or apt-get upgrade , my cirrus card does not work anymore image
  • clem57
    That is exactly what you put in the issue.
    so,how to use this card to broadcast audio over the network to a PC ??
  • jamesjohn911
    0 jamesjohn911 over 10 years ago
    From time to time Raspbian will update the kernel+GPU firmware package.
    If you do an apt-get upgrade the Cirrus kernel will be replaced with the official Raspbian kernel and the sound card no longer works.
    You can prevent Raspbian kernel updates by putting the raspberrypi-bootloader package on hold
    sudo apt-mark hold raspberrypi-bootloader
    Note: this will also disable GPU firmware updates.
    If you want to update the GPU firmware but not the kernel
    install the rpi-update package
    and then update the GPU firmware
    with this command: sudo SKIP_KERNEL=1 rpi-update
    hope this helps my raspi brothers & sisters
    sudo apt-get peaceout
    sudo apt-get upgrade islam -p
    0 e14 Contributor over 10 years ago in reply to jamesjohn911
    thank you Mr James image :*
  • jamesjohn911
    0 jamesjohn911 over 10 years ago in reply to e14 Contributor
    Hi Marwen, no probs glad it worked for you
    i suffered this same problem when i first got my Cirrus Audio Card
    it drove me nuts for a few days until someone helped me out to fix it
    if you get stuck again message me and il see if i can help
    take care my man image
    Ok thank you very mush Mr James image image
    I have other Probléme : https://www.element14.com/community/message/176136/l/exconnection#176136
    merci d'avance  image
