Raspberry Pi Forum 7” Touchscreen Display + rPi 3 + Right Click (Long Click)?
  • Subscribers 708 subscribers
  • Views 1592 views
  • right click
  • setup
  • jessie
  • 7" touchscreen display
  • raspberry pi 3
  • long click
Hello!
The screen works really wll with my Pi3, except I have not been able to setup right-clicking or long-clicking.
I'm running Jessie and the instructions for the Wheezy do not work on Jessie.
Has anyone been able to setup the screen for right-click or long-click?
Thanks.
  • Nate1616
    0 Nate1616 over 10 years ago
    Mario-
    I would follow this link https://www.raspberrypi.org/forums/viewtopic.php?f=108&t=121602  It discusses your questions with a solution.
    Nate
  • jimmayhugh
    0 jimmayhugh over 10 years ago in reply to Nate1616
    Doesn't appear to work with Jessie...
  • flippi76
    0 flippi76 over 9 years ago
    Everyone who is having problems with Jessie and the debug message "No valid axis inversion data found".
    I think I found a workaround:
    # Install packages
    sudo apt-get update && sudo apt-get install build-essential libx11-dev libxi-dev x11proto-randr-dev libxrandr-dev libxtst-dev xserver-xorg-input-evdev
    # Install twofing
    cd ~
    wget http://plippo.de/dwl/twofing/twofing-0.1.2.tar.gz
    tar -xvzf twofing-0.1.2.tar.gz
    cd twofing-0.1.2
    make && sudo make install
    # create a new rule-file
    sudo nano /etc/udev/rules.d/70-touchscreen-raspberrypi.rules
    # add the following line
    KERNEL=="event*",ATTRS{name}=="FT5406 memory based driver",SYMLINK+="twofingtouch",MODE="0440"
    # modify X11 config
    sudo nano /usr/share/X11/xorg.conf.d/40-libinput.conf
    # add the following lines at the end of the file
    Section "InputClass"
       Identifier "calibration"
       Driver "evdev"
       MatchProduct "FT5406 memory based driver"
       Option "EmulateThirdButton" "1"
       Option "EmulateThirdButtonTimeout" "750"
       Option "EmulateThirdButtonMoveThreshold" "30"
    EndSection
    # Reboot your device
    sudo reboot
    # Check if twofing is working
    twofing --debug
    # Add twofing to autostart
    nano ~/.config/lxsession/LXDE-pi/autostart
    # add the line at the end
    @/usr/bin/twofing
    # Cleanup
    cd ~
    rm -rf ~/twofing-0.1.2
  • pjocke
    0 pjocke over 9 years ago in reply to flippi76
    I am trying to get this to work on a Raspberry Pi 3 with the Pi Foundation 7" touch screen using Raspbian Stretch, but without any luck. I stil get the message saying "no valid axis inversion data found." Any ideas?
