Raspberry Pi Forum Anyone any experience of installing OpenOB on RPi?
  • Replies 17 replies
  • Answers 3 answers
  • Subscribers 710 subscribers
  • Views 3774 views
  • cirrus-logic-audio-card
  • raspberry-pi3
  • openob
I'm wanting to install OpenOB on a Pi 3 with Wolfson/Cirrus audio card.
I've got the card drivers running and it's detected by ALSA.
I was following the installation tutorial  here -> https://jamesharrison.github.io/openob/tutorial.html
but I'm baulked at installing gstreamer0.10-ffmpeg which seems to be obseleted in Debian 8, and presumably therefore Raspbian Jessie. I just wondered if anybody had done this and overcome this issue?
I could build it from sources I guess if necessary, but I know nothing of the gstreamer architecture.
Kind regards,
Alan
  • kylelmartin
    0 kylelmartin over 9 years ago in reply to clem57
    I did find the Pitivi page, but then I needed to install flatpak, then it appeared they didn't have a specific version for Raspbian Jessie......and on and on.
    Thanks for the link.
  • kylelmartin
    0 kylelmartin over 9 years ago in reply to kylelmartin
    Progress has been made...kinda. I have OpenOB installed on 2 RPI3-s.
    10.0.0.114 is the transmitter and config server.
    10.0.0.110 is the receiver.
    I can start the receiver with ¨openob 10.0.0.114 test-rex-node test-link rx¨ and eventually get ¨Waiting for transmitter capabilites...¨
    but when I fire up the transmitter with the line below, this is what I get.
    openob 10.0.0.114 test-tx-node test-link tx 10.0.0.110
    2017-03-19 00:22:05,042 - openob.link.test-link.config - INFO - Connecting to configuration host 10.0.0.114
    2017-03-19 00:22:05,051 - openob.node.test-tx-node - INFO - Link test-link initial setup start on test-tx-node
    2017-03-19 00:22:05,052 - openob.node.test-tx-node.link.test-link - INFO - Starting up transmitter
    2017-03-19 00:22:05,059 - openob.node.test-tx-node.link.test-link.tx - INFO - Creating RTP transmission pipeline
    (128000, False, True)
    2017-03-19 00:22:05,121 - openob.node.test-tx-node.link.test-link.tx - INFO - Set receiver to 10.0.0.110:3000
    (python:1117): GStreamer-CRITICAL **: range start is not smaller than end for `GstIntRange'
    Additionally if I don´t have the jack server running, I just get errors.
  • kylelmartin
    If I don´t start Jack I get the following
    2017-03-19 00:45:17,982 - openob.node.test-tx-node.link.test-link.tx - INFO - Set receiver to 10.0.0.110:3000
    Cannot connect to server socket err = No such file or directory
    Cannot connect to server request channel
    jack server is not running or cannot be started
    AL lib: (WW) alc_initconfig: Failed to initialize backend "pulse"
    AL lib: (EE) alsa_open_capture: Could not open capture device 'default': No such file or directory
    might this offer a clue?
  • clem57
    0 clem57 over 9 years ago in reply to kylelmartin
    You may want to check on https://github.com/TheImagingSource/tiscamera/issues/21 They have the same error and have open this issue...
  • kylelmartin
    This problem seems to go away if I have jack running.
    Unfortunately, I was under the impression that Jack was not necessary to run OpenOB.
    Previous versions of OpenOB, as shown on this page (Broadcast-quality OBs with Raspberry Pis – Talk Unafraid ) indicate that you can specify hardware rather than rely on an audio server.
  • kylelmartin
    OK. Installed everything on both transmitter and receiver RPI3's.
    But the units seem to not be seeing each other.
    Here is the transmitter side:
    pi@Transmitter-Pi:~ $ openob 10.0.0.114 test-tx-node test-link tx 10.0.0.110
    2017-03-24 22:07:23,930 - openob.link.test-link.config - INFO - Connecting to configuration host 10.0.0.114
    2017-03-24 22:07:23,938 - openob.node.test-tx-node - INFO - Link test-link initial setup start on test-tx-node
    2017-03-24 22:07:23,940 - openob.node.test-tx-node.link.test-link - INFO - Starting up transmitter
    2017-03-24 22:07:23,941 - openob.node.test-tx-node.link.test-link.tx - INFO - Creating RTP transmission pipeline
    2017-03-24 22:07:24,002 - openob.node.test-tx-node.link.test-link.tx - INFO - Set receiver to 10.0.0.110:3000
    and the transmitter just sits there.
    Here is the receiver side:
    pi@KZZM-Rec-Pi:~ $ openob 10.0.0.114 test-rx-node test-link rx
    2017-03-24 17:07:15,253 - openob.link.test-link.config - INFO - Connecting to configuration host 10.0.0.114
    2017-03-24 17:07:15,272 - openob.node.test-rx-node - INFO - Link test-link initial setup start on test-rx-node
    2017-03-24 17:07:15,275 - openob.node.test-rx-node.link.test-link - INFO - Waiting for transmitter capabilities...
    and the receiver just sits there.
    Am I missing some config info?
    Thanks.
  • janosnet
    0 janosnet over 7 years ago in reply to kylelmartin
    Hello Kyle Martin
    Is possible share the step to setup and installing openOb into Rpi3?? can´t install in my Rpi with information of 2014. many thanks
