Raspberry Pi Forum Anyone any experience of installing OpenOB on RPi?
  • Replies 17 replies
  • Answers 3 answers
  • Subscribers 710 subscribers
  • Views 3714 views
  • cirrus-logic-audio-card
  • raspberry-pi3
  • openob
I'm wanting to install OpenOB on a Pi 3 with Wolfson/Cirrus audio card.
I've got the card drivers running and it's detected by ALSA.
I was following the installation tutorial  here -> https://jamesharrison.github.io/openob/tutorial.html
but I'm baulked at installing gstreamer0.10-ffmpeg which seems to be obseleted in Debian 8, and presumably therefore Raspbian Jessie. I just wondered if anybody had done this and overcome this issue?
I could build it from sources I guess if necessary, but I know nothing of the gstreamer architecture.
Kind regards,
Alan
  • Nate1616
    0 Nate1616 over 10 years ago
    Alan-
    Debian 8 at one point switched to libav from ffmpeg which eliminated gstreamer0.10-ffmpeg.  They did go back to ffmpeg but don't think gstreamer0.10-ffmpeg is there yet.  You can try to install unsupported packages.  Here is a link  https://launchpad.net/~mc3man/+archive/ubuntu/gstffmpeg-keep
    Nate
  • moorh
    0 moorh over 9 years ago
    Hallo Alan,
    How are you going with OpenOB on your RPi3 with cirrus logic audio?
    I'm on the same project and finally got my cirrus working on the RPi3.
    encounterd the same problem with installing the ffmpeg
    And also installing the redis-server
    up and running yet?
    just wondering of you did, maybe giving me some pionters :-)
    regards,
    Edwin
  • leillo
    0 leillo over 9 years ago
    I am having the same difficulties. Has anyone had any luck?
  • clem57
    0 clem57 over 9 years ago
    Has anyone checked https://jamesharrison.github.io/openob/tutorial.html
  • moorh
    For redis-server try, i got it running:
    https://redis.io/topics/quickstart
    For gstreamer try:
    sudo apt-get install gstreamer-tools
    for instructions this was helpful:
    http://home.kpn.nl/h.sommen/configureren.pdf
    Edwin
  • kylelmartin
    0 kylelmartin over 9 years ago
    I'm jumping on the ¨trying to do this too¨ bandwagon.
    I would be happy to get OpenOB working with the simple USB audio adapters ($50) or the Behringer UCA202.
    I have the Cirrus, but have given up for now.
    Tried installing on RPI3 from instructions on OpenOB´s homepage - but it became a chaotic hunt for dependencies.
    I´ve been installing OpenOB using this guide and thus far have had no dependency problems.
    http://lists.talkunafraid.co.uk/pipermail/openob-users/2016-May/000384.html
    Will report back as I learn more.
  • kylelmartin
    0 kylelmartin over 9 years ago in reply to kylelmartin
    Everything installed smoothly using the link above, but when I try to make the connection listed on james harrison´s tutorial page  - where it says
    openob 192.168.0.10 test-rx-node test-link rx
    I get the following error
    Traceback (most recent call last):
      File "/usr/local/bin/openob", line 9, in <module>
        from openob.node import Node
      File "/usr/local/lib/python2.7/dist-packages/openob/node.py", line 4, in <module>
        from openob.rtp.tx import RTPTransmitter
      File "/usr/local/lib/python2.7/dist-packages/openob/rtp/tx.py", line 2, in <module>
        import pygst
    ImportError: No module named pygst
    Any ideas whatś gone wrong?
  • clem57
    0 clem57 over 9 years ago in reply to kylelmartin
    Tells me the code is Python based and needs to install PyGST Tutorial/Getting Started - Pitivi wiki . Good luck, hoping this works.
  • kylelmartin
    0 kylelmartin over 9 years ago in reply to clem57
    That link appears to be very broken in 2017.
    Did this -
    sudo apt-get install python-gst0.10
  • clem57
    Did they fix it? Here is updated link Pitivi
