Raspberry Pi Forum Conversion between simulink and C code
  • Subscribers 705 subscribers
  • Views 813 views
  • ccode
  • ras_pi3
  • simulink
What are the available ways to convert a Simulink model to C code in order to run this code on Raspberry Pi 3??
  • clem57
    0 clem57 over 10 years ago
    How about Automatic Code Generation - Simulink Coder
    0 e14 Contributor over 10 years ago in reply to clem57
    okay, have you tried it before?
    0 michaelkellett over 10 years ago in reply to clem57
    Unless Abdel has access to an academic or home license he may choke on the price.
    This is available to students (and cheap) but I'm not absolutely sure that it generates extractable C for the PI.
    Programming Raspberry Pi with Simulink - Simulink Video - MathWorks United Kingdom
    I use Simulink from time to time to develop  and test algorithms but I never use automatic coding tools (not totally set against them but the cost is very high for commercial work and I wouldn't use them enough to see benefit).
    @Abdel - can you post your Simulink model or explain what you are working on ?
  • madhugovindarajan
    0 madhugovindarajan over 10 years ago
    If you would like to see the C code that is being deployed to the Raspberry Pi then you need the coder products as some of the others have mentioned here. If you are merely looking to deploy algorithms to the Pi 3 then take a look at this free support package - Raspberry Pi Support from Simulink - Hardware Support
