Raspberry Pi Forum How do I install wacom.ko on the newest Pi...
  • Replies 9 replies
  • Subscribers 706 subscribers
  • Views 1827 views
I found a file on the RasPi forum for installing a Wacom Kernel on Raspian but it is for the last edition of raspberry pi? I can't move it in the Tablet folder for some reason....
  • clem57
    0 clem57 over 10 years ago
    This sounds like permission problem. If so, use sudo before the mv/cp command.
    Clem
  • clem57
    I think you need to compile looking at https://www.raspberrypi.org/forums/viewtopic.php?f=28&t=103505
    0 e14 Contributor over 10 years ago in reply to clem57
    Ho0w do I move the file into the folder from downloads?
    https://www.raspberrypi.org/forums/viewtopic.php?f=63&t=122368  Okay this threade suposbely contains the solution.. But I am new to LINUX and Python and don't know how to run the python script...
    I tried to run the Python Script with "Sudo Bash" but the script just displayed a bunch of errors...
  • clem57
    0 clem57 over 10 years ago in reply to e14 Contributor
    Inside a terminal window, try to "cd" into the directory that has rpi-source script.
    Next just enter:
    ./rpi-source
    Clem
    PS. The directions assume some specific user knowledge of Linux unfortunately.
    ./rpi-source: line 9: import: command not found
    ./rpi-source: line 10: import: command not found
    ./rpi-source: line 11: import: command not found
    ./rpi-source: line 12: import: command not found
    ./rpi-source: line 13: import: command not found
    ./rpi-source: line 14: import: command not found
    ./rpi-source: line 15: import: command not found
    ./rpi-source: line 16: import: command not found
    ./rpi-source: line 17: import: command not found
    ./rpi-source: line 18: import: command not found
    ./rpi-source: line 19: import: command not found
    ./rpi-source: line 22: DISK_USAGE_MB: command not found
    ./rpi-source: line 24: wiki: command not found
    ./rpi-source: line 25: script_repo: command not found
    ./rpi-source: line 27: syntax error near unexpected token `('
    ./rpi-source: line 27: `update_tag_file = os.path.join(os.environ.get('HOME'), '.rpi-source')'
    0 shabaz over 10 years ago in reply to e14 Contributor
    Was the first error on line 9, or earlier?
    You've not pasted what you've typed, so it is ambiguous if you've just paste a random snippet of the errors or from the first error.
    Can you also try typing:
    python rpi-source
    (just in case it makes a difference)
    And also paste what you type and the entire CLI output. Also the contents of your rpi-source file would be good to see.
    If you can't attach the files, then you can use some web based service like pastebin.com
    and then just supply the URL.
    0 e14 Contributor over 10 years ago in reply to shabaz
    I managed to use the Tar File input-wacom-0.31.0 to get the Wacom.ko into the right folder... Now how to I proceed to set it up...
