Raspberry Pi Forum Pi3 Wireless Hub
  • Answers 2 answers
  • Subscribers 707 subscribers
  • Views 824 views
Pi3 Wireless Hub
jack.chaney56
jack.chaney56 over 10 years ago
I was wondering if anyone has had a chance to create a wireless network hub using the new Raspberry Pi 3?
Seems to me the simplest would be to just set it up as a gateway, and then you can put a virtual node trap in place as a firewall.
Let me know.
  • clem57
    0 clem57 over 10 years ago
    Guess what jack.chaney56, I will grant your wish. See https://www.pi-point.co.uk/documentation/ for software to create Raspberry Pi 3 into a free acces point on your network. Even has a honey trap! image
    Clem
    0 balearicdynamics over 10 years ago in reply to clem57
    Hi Clem,
    a problem (mentioned on the same site) is that the last Raspbian images (e.g. the PI3 full supporting the Bluettooth too with a decent GUI tool) does not manages the network connections in the same way so the project of the suggested link didn't work. Need to wait a while they release an updated image and documentation... Sic.
    Enrico
  • clem57
    0 clem57 over 10 years ago in reply to balearicdynamics
    jack.chaney56 Enrico has a point. The updates have to move to new file as in Configuring a Static IP for a Raspberry Pi running Raspbian – TechSneeze.com for Jessie, follow this:
    sudo nano /etc/dhcpcd.conf
    At the bottom of the file you will need to add settings such as:
    interface eth0
    static ip_address=192.168.1.31/24
    static routers=192.168.1.1
    static domain_name_servers=192.168.1.1 8.8.8.8 4.2.2.1
    static domain_search=example.com
    static domain_name=example.com
    Clem
    Hi Jack,
          I've been working on something similar to this on an up to date version of Jessie. Here's what I've done so far:
    - I am setting up a captive portal so I have been following the below instructions:
    https://www.engetsu-consulting.com/raspberry-pi-raspbian-rogue-access-point-ap-landing-page-captive-portal
    The first part of these instructions link to adafruit instructions:
    https://learn.adafruit.com/setting-up-a-raspberry-pi-as-a-wifi-access-point/overview
    Follow the adafruit instructions and when you get to the part where you install the 'isc-dhcp-server' you will need to use the fix at the link below:
    https://forums.adafruit.com/viewtopic.php?f=19&t=47716
    It is this post:
    sk00t3r Posts: 2Joined: Sat Jan 04, 2014 6:34 pm
    There is one problem with it though. The wget for th zip file will not work. you need to go to the below page to download the correct zip file and transfer it onto your pi manually:
    Realtek
    the one you want is the Linux version of the 'RTL8192CU' driver.
    When you have followed the rest of the fix from the Post and the rest of the adafruit instructions you should have a working WIFI access point.
    Hopefully this helps
