Raspberry Pi Forum Raspberry Pi3 Does not boot up - Green light does not lit
  • Replies 34 replies
  • Answers 4 answers
  • Subscribers 719 subscribers
  • Views 9308 views
  • pi3 does not boot up
I purchased a Raspberry Pi3 last week, after spending couple of days trying to get it to boot up I gave up and purchase another one. I am having the same issues, it just would not boot up, i.e. the green light does not lit -- which I think means that is Not reading the SD card to load the Operating System. This is what I have done so far:
Used a 5v/2A power supply, use a 5v/2.4A power supply.
Used the SD with the preloaded OS that I purchased - no luck
Purchase another SD card, formatted it and load Noobs sw on it - still no luck
I removed every thing that is plugged in the PI3 except for the power supply, still no luck.
Anyone out there who is experiencing the same issue???
Does your one works out of the box?
What am i doing wrong???
What should the voltage/Amp for the power supply be? is it 5v/2.5A?
Help please.. Gerard
  • lyubcho
    0 lyubcho over 7 years ago
    Also the minimal size of Micro SD card on the rpi is 16 Gigs and it has to be formated to FAT32 Edit: It might not work with higher then 32gb like some motherboards with ram
  • nona96
    0 nona96 over 7 years ago
    can you suggest a book or a website which teaches about raspberry pi?
    i am a complete new user and i need to implement it in my project.
  • beacon_dave
    0 beacon_dave over 7 years ago in reply to nona96
    "can you suggest a book or a website which teaches about raspberry pi?"
    Main website:
    https://www.raspberrypi.org/
    Getting Started with Raspberry Pi:
    https://www.raspberrypi.org/help/
    Beginners Guide eBook:
    https://www.raspberrypi.org/magpi-issues/Beginners_Guide_v1.pdf
    Quick Start eBook:
    https://www.raspberrypi.org/magpi-issues/QuickStart_v1.pdf
    Beginners Book eBook:
    https://www.raspberrypi.org/magpi-issues/Beginners_Book_v1.pdf
    The Raspbery Pi Foundation also have three new MOOC courses on Futurelearn starting this month:
    https://www.futurelearn.com/partners/raspberry-pi
  • clem57
    0 clem57 over 6 years ago in reply to bushra
    reload SD card or try another SD  card
