Raspberry Pi Forum Wifi Issues on Raspberry Pi 3
  • Subscribers 706 subscribers
  • Views 1323 views
  • wifi
  • help
  • raspberry_pi_space
Hello Friends - I am a newbie Pi user, purchased my Pi 3 device a few days ago.
I have been having difficulty setting up the wifi on Rasbian Jessie.
When I enter my wep password into the field.
Nothing happens.
Also Please note, when I hover the mouse over the wifi icon - it says "wlan0: not associated".
Any help would be greatly appreciated.
  • RParkerE
    0 RParkerE over 10 years ago
    With the limited information you have given, I am not quite sure what the issue is other than it not connecting. A little more detail may help in finding a solution. You can also open up terminal and set the wireless connection up through it. edit (sudo nano) the /etc/wpa_supplicant/wpa_supplicant.conf  file. You will need to either edit or add the following lines:
    network={
        ssid="AP Name"
        wep_key0="Password"
        key_mgmt=NONE #I believe this line is optional
    EDIT: Changed the additional lines for WEP rather than WPA
    0 shabaz over 10 years ago
    Presumably you really meant WPA, although the question mentioned 'wep'.
    With WEP, the psk field mentioned in Parker's response is replaced with something else but WPA is strongly advised. WEP can be cracked within minutes.
    I would be surprised if WEP was even tested much these days in the raspbian desktop.
  • RParkerE
    0 RParkerE over 10 years ago in reply to shabaz
    I didn't even realize it was asking about WEP since it is so uncommon now a days. However it looks like others have had this same issue if it is WEP since I doubt it is maintained. An option I found from here is to download network-config (apt-get install network-config). It should allow one to connect to WEP networks with a nice GUI to help.
  • electrorubixtech
    0 electrorubixtech over 10 years ago
    I have downloaded resbian Jessie lite because it's small but when I tried to connect a WiFi network nothing happens, but when I downloaded the full image WiFi worked well try to reinstall the resbian is (full image)
