Raspberry Pi Forum Wireless serial connection between raspberry pi and NodeMCU (ESP8266) without internet
  • Subscribers 706 subscribers
  • Views 3535 views
  • adhoc
  • wlan
  • internet of things
  • esp8266
  • raspberry-pi
  • raspberrypi
  • nodemcu
  • serial wifi
I want to establish a wireless connection between NodeMCU and Raspberry Pi 3.
I want it such that both the devices can be connected directly without any other wifi connection(Even if internet is not available they should be able to transmit and receive data).
And How can I observe the data received or transmitted on terminal ?
  • ravi_butani
    0 ravi_butani over 10 years ago
    You can configure nodeMcu as WiFi client and setup your Pi as access point... U can Use UDP protocol on nodeMCU to talk with Pi... At Pi end you can write simple python code to talk with nodeMcu using UDP....
    https://wiki.python.org/moin/UdpCommunication  refer this guide for UDP implementation On Pi...
    https://learn.adafruit.com/setting-up-a-raspberry-pi-as-a-wifi-access-point/overview  refer this guide for setup Access Point on Pi...
    in nodeMcu arduino IDE go to example select wifi--> wifiUDPSendReceiveString Example and change #include <WiFi.h> to #include <ESP8266WiFi.h> and Loadit to your nodeMcu..
    Hope it helps...
    Ravi
    0 e14 Contributor over 10 years ago in reply to ravi_butani
    Hello Ravi,
    Thank for your guidance.
    I am want to connect both devices using WLAN. I am facing difficulty when internet connection is not available.
    I want just a simple wireless connection between NodeMCU and Raspberry Pi 3 independent of availability of internet.
    Pallav
    Also
    Is there any way I can observe received sensor data through Wifi on Raspberry Pi ? Just like Serial Terminal or Bluetooth Terminal.
  • oksbwn
    0 oksbwn over 10 years ago in reply to e14 Contributor
    ravi_butani is right you can configure either of the device as access point to have direct one-to-one connection. For this you don't have to be dependent on internet. I am not fully aware of UDP on Pi but you can create webpages on Pi by making it a server and log your sensor data to Raspberry Pi.
    To configure Pi as a server using  Apache, MySQL, PHP you can checkout the below video...
    https://goo.gl/yPQX7v
  • naveenchand435
    0 naveenchand435 over 9 years ago
    You can use Php mysql to monitor your data. There are lots of examples found on internet
