Raspberry Pi Forum Switch to determine what program boots up on raspbery pi
  • Subscribers 706 subscribers
  • Views 721 views
  • emulation
  • raspbery pi
  • switch
hey guys, i am running a retro-pie install with kodi on it.
the enclosure is a gutted out genesis with a working startup/ shutdown switch and power led.
i have been looking for a tutorial or some information on how i would go about putting a on off led switch that if pressed in will change what program boot http://www.portalmartin.com/saklar-switch/saklar-push-on-off-bulat-warna-dengan-lampu-dc-3v
i'm sure it is possible with a custom start up script but i was just wondering if any of you guys have done something similar?
Saklar Push On Off Bulat Warna Dengan Lampu DC 3V - Portal Martin, this isn't the exact switch i have but its the same idea
also hello everyone this is my first post! i was brought here by the ben heck show
  • oksbwn
    0 oksbwn over 10 years ago
    You can run a script background which looks for GPIO pin status (Switch Connected) and according to the input it runs the desired application......
    that's the path i am thinking about going down, i am going to make it a startup script and check the state of the button/ switch, if the pins are making contact boot emulation station, elif boot kodi.
    i just physically installed the button into the case, i am new to working with this type of button, its seems like the positive an neg are for powering the led and the other side is connecting/ breaking the circuit
