Raspberry Pi Forum info on board
  • Replies 8 replies
  • Subscribers 706 subscribers
  • Views 1438 views
  • frontpage
info on board
izephire
izephire over 9 years ago
I am trying to find info on this board and see how I can hook it up to my raspberry pi 3.  it is on a 7in screen that came out of a car entertainment system
  • gadget.iom
    0 gadget.iom over 9 years ago
    I did a brief search using the references on the board silkscreen (to no avail). The cable header makes me think that you might be able to provide an NTSC/PAL signal onto a couple of those pins and get some video, but without pinout information this task just got a whole lot harder.
    I did have slightly more success with the partial part number on the white plastic label (bottom left) but could't get a whole number.
  • izephire
    0 izephire over 9 years ago in reply to gadget.iom
    I did search on google for the board (for a couple of hours) I think it is a dc converter board for an lcd screen but not to sure.
    as for the other number if it is thr lq070 number the whole part number is lq070t5crq1
    0 e14 Contributor over 9 years ago in reply to izephire
    I found a loosely similar board which points to it being an inverter for the LCD's backlight by googling "pwb 12188" here:  https://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&cad=rja&uact=8&ved=0ahUKEwjnl4WOjvbPAhWKL8AKHSYtAeIQFg… the url indicates that its a product from a larger range. I wouldn't think there's much use looking deeper into this link though.
  • izephire
    0 izephire over 9 years ago in reply to e14 Contributor
    so do you think that I can hook it up to my raspberry pi or should I just use the screen
    Without knowing what its power requirements definitely are then its hard to say. Probably not is the answer, you could try powering the backlight inverter from another source
  • izephire
    I have found a data sheet for the screen but cant see hoe to post it.  but I think the board on back of the screen is so it can work wit 12 to 14v car electrical systems
    none LED backlights can need >1000V to start up, thats what the inverters do.
    0 shabaz over 9 years ago
    Looks like you have two threads regarding the same topic
    how can i hook this lcd screen up to a raspberry pi?
    However you've placed the LCD datasheet on the other thread, whereas it would have helped people who were responding to you on this thread.
    It just makes it difficult for people to help when multiple threads are created for the same topic.
    With the combined information from that thread and this one, it is clear that the display has a composite input, and the adapter board on the rear is
    responsible for providing the supply and backlight voltage. You could follow the traces to figure out the pinout based on the datasheet. Often with these
    car screens yellow is the composite signal, and red and black are the supply, but you'll need to decipher the rest or perhaps look at the connectors at
    the ends of the unit from which you removed the screen.
