Raspberry Pi Forum what is the best option for 7-9 year olds?
  • Replies 15 replies
  • Answers 8 answers
  • Subscribers 710 subscribers
  • Views 3397 views
elliotlewis
elliotlewis over 9 years ago
  • flymediatech
    0 flymediatech over 9 years ago
    What options... What kind of options do you want.
  • elliotlewis
    0 elliotlewis over 9 years ago in reply to flymediatech
    I have a seven year old daughter & and 9 year old godson and was thinking of thinking of buying them Raspberry Pi’s for Christmas though was not sure where to start, any thoughts would be greatly appreciated.
    Elliot
  • Robert Peter Oakes
    0 Robert Peter Oakes over 9 years ago in reply to elliotlewis
    I guess the question is more... What do you see them learning
    The PI is an educational platform and a very good one, but not really aimed at the age group in question
    Something more appropriate may be this
    https://www.microduino.cc/index-mcookie
    I am currently reviewing the Advanced Cookie set and it seems very good, and almost imposible to connect up wrong due to the magnetic parts involved and that they use POGO pins.  Think Lego Arduino
  • clem57
    0 clem57 over 9 years ago in reply to Robert Peter Oakes
    I agree a more toy like would ease them into the fun and later a Pi would be for older say early teens. Make sure it is what they want and not what you want.
    Clem
    0 Robert Peter Oakes over 9 years ago in reply to clem57
    Yes, it is so tempting... a bit like buying train sets for a 2 year old image
  • gpolder
    0 gpolder over 9 years ago in reply to elliotlewis
    give them a pi 3, and a official raspberry pi display in a SmartiPi LEGO compatible case, with a small keyboard and mouse and let them program Scratch.
    Gerrit.
  • uscdadnyc
    0 uscdadnyc over 9 years ago
    I posted on the Thread "LCD" in Raspberry Pi. [This Thread was initialed by Andy Clark (workshopshed)] AAR please go to this Thread, where I used the same equipment as described by Geritt Polder, I went further in that I Freed the hidden HDMI Connector on the RaspPi 3 B. This involved cutting-away at the back of the SmartiPi Case w/ a Dremel (tm = trademark) Tool. Not exactly something done by a 7-9 year old, but fine when done by a Responsible Adult. There are Photos posted on that Thread. BTW this combo by myself (USCDADNYC = Edward Yee) and Geritt Ponder) does hide the uSDcard Slot w/i the case. i.e. not easy to get to. However I did see at the MCM Electronics Site, an adapter which extends uSDcard slot into a flat-cable. At the other end is a full-size SDcard Female Connector. This can be used to bring-out the uSDcard slot from w/i the case. AAR by doing my modification, a 7-9yr old might like the modification process. (cutting away at the black Plastic)
    USCDADNYC (NY NY USA)
    0 dougw over 9 years ago
    The BBC micro:bit was targeted at this age group...might be worth checking out....
    https://www.microbit.co.uk/
    BBC micro:bit | Farnell element14
  • elliotlewis
    All, Thank you very much for all your thoughts. Much appreciated.
    0 mcb1 over 9 years ago
    Some of the electronic kits that they assemble can also be a great starting point.
    I've introduced 10yr olds into Arduino, but it really depends on what they are interested in to start with.
    If they pull things apart to see how they work, and then put them back together, or extract parts from something to use in another item, then they are much more likely to be hands on and will enjoy the 'construction' type environment.
    Many think they want to program games, and I agree with others that the RP is not really suited to that age (generally speaking).
    While scratch is a programming language, it comes standard on Macs I believe and can certainly be downloaded onto something to use ...if you must.
    We run an introduction to Arduino in schools and myself and a few software guys think that drag and drop software such as scratch doesn't help makes them good programmers.
    Yes it is a little biased (you should hear what they say about html programming) ...
    Robotics is always a good one, and they can be an inexpensive one to start, which may lead to more advanced versions as their capabilities outgrow the hardware.
    Whatever you choose it needs to be easy to get results, even if it is to flash lights. The quick interaction is what hooks them and once hooked they may continue.
    As dougw said the BBC Micro or even some Codebugs are a really good starting point.
    Good luck
