Raspberry Pi Forum My Pi 2 has quit saving files after a power reset.
  • Replies 16 replies
  • Answers 2 answers
  • Subscribers 709 subscribers
  • Views 4387 views
wadeelmore
wadeelmore over 9 years ago
I can create files and programs, but when I power cycle the Pi, all the new content is gone.  I have tried to edit an existing file.  The changes were gone after the power cycle.  File manager shows 2.4G free.  Any thought?
  • clem57
    0 clem57 over 9 years ago
    Enter the following commands and post output here:
    df -h
    uname -r
    Thanks, Clem
  • wadeelmore
    0 wadeelmore over 9 years ago in reply to clem57
    pi@raspberrypib:~ $ df -h
    Filesystem      Size  Used Avail Use% Mounted on
    /dev/root       7.2G  4.4G  2.5G  64% /
    devtmpfs        427M     0  427M   0% /dev
    tmpfs           432M     0  432M   0% /dev/shm
    tmpfs           432M   12M  420M   3% /run
    tmpfs           5.0M  4.0K  5.0M   1% /run/lock
    tmpfs           432M     0  432M   0% /sys/fs/cgroup
    /dev/mmcblk0p1   60M   20M   41M  34% /boot
    tmpfs            87M     0   87M   0% /run/user/1000
    /dev/sda1       247M  552K  247M   1% /media/pi/USB DISK
    pi@raspberrypib:~ $ uname -r
    4.1.19-v7+
    pi@raspberrypib:~ $
  • jgerred
    0 jgerred over 9 years ago
    Check and see if the partitions are mounted read only for some reason.  Use the command  "mount" (minus the quote marks) and look for (ro) at the end of any of the lines in the output.
  • johnbeetem
    0 johnbeetem over 9 years ago
    GNU/Linux first writes files to RAM buffers and later writes them to non-volatile storage like an SD card or Flash drive.  If you hard reset or power down before the files are written to non-volatile storage, you'll lose the changes.
    Use the "sync" command write changes to non-volatile storage immediately.  Enter "man sync" in a terminal window for more information.
    Use the "shutdown" command before turning off power.  If you're using a GUI, there should be a power down command somewhere to shut down safely.
  • wadeelmore
    0 wadeelmore over 9 years ago in reply to jgerred
    The very last line has '...flash,errors=remount-ro,...'.
    I don't see any errors.
  • wadeelmore
    0 wadeelmore over 9 years ago in reply to johnbeetem
    I do use the GUI shutdown before power down.  I wait until the touch screen goes to just lines, then pull the power.
    I tried the 'sync' commend.  Same result, all changes lost.  The files revert to a mid Jan 2016 version.   Luckily I have a habit of saving copies to a USB drive.
    I am considering formatting and reloading Jessie to the SD card.
  • rew
    0 rew over 9 years ago in reply to wadeelmore
    IF the system would remount your file system read only (due to an error), the write that triggered it has already returned and it is impossible for the system to retroactively forward the error to the application.
    But all subsequent writes to a readonly mounted file system would fail immediately and you'd get errors.
    The behavior that you describe sounds like the wanted behavior for a guest account. Could it be that your account is flagged as a guest account? (I'm not familiar how guest accounts work at the lower level so I'm not even sure that it is possible to tag a normal account as  a guest account).
  • jgerred
    0 jgerred over 9 years ago in reply to wadeelmore
    It sounds like that for some reason at least one partition is being mounted read-only.  Without the full output of the command it is difficult to diagnose further.  Try running "dmesg" and look for errors there, also look in /var/log/messages for any error messages.
    ---Edit---
    This is not the issue, as Roger Wolff pointed out, if the file system went read-only your process should throw an error and your editor would not let you save the file
  • rew
    0 rew over 9 years ago in reply to jgerred
    Again... The process triggering the error would not be getting an error. But all subsequent writes would immediately fail with read-only file system.
    I created a test read-only filesystem. When I edit a file with nano I get the following status message:
    [ Warning: Modifying a file which is not locked, check directory permission? ]
    Then when I try to exit and save the file, I get:
    [ Error writing test.txt: Read-only file system ]
    and nano refuses to exit. If your home dir would remount readonly due to errors you'd notice it.
  • jgerred
    0 jgerred over 9 years ago in reply to rew
    Good point.  I have seen file systems go read only that didn't impact home directories.  It depends on the layout of the SD card, then again, on a Pi it is probably just one big file system on the SD card.  I was thinking in the mind set of a large hard drive with separate partitions for home, boot, var, etc, and should have looked closer at his df output.
