Raspberry Pi Forum Is there anyway to fix a (9V power) burned pi
  • Replies 19 replies
  • Answers 5 answers
  • Subscribers 709 subscribers
  • Views 8633 views
  • not booting
  • led light not flashing
  • high voltage on pi
js1963on
js1963on over 9 years ago
I think I accidentally connect a 9V battery pi to the pi and it flashed and turned off.
I think I might burned the pi by doing that because I'm not able to boot it any more.
So now if I connect the normal power cord to the pi, both red and green led light up but no flashing.
I tried to refreshing the os on the sd card and tried other working sd card as well, same problem stays.
Anyone has any suggestions of what to do? Is there anyway to fix the burned pi?
Thank you.
  • rsc
    0 rsc over 9 years ago
    Depending on what's cooked, you may be able to fix it.  Look at the schematics for your board and start testing points with a voltmeter starting from the power supply.
    Check the 3v and 5v pins on the GPIO header first.
    https://github.com/raspberrypi/documentation/tree/master/hardware/raspberrypi/schematics
    If the LEDs are still on, it's hard to say where the problem is.
    Scott
  • js1963on
    0 js1963on over 9 years ago in reply to rsc
    Thank you for your quick reply.
    The board I have is Raspberry Pi 2 Model B V1.1
    I do have a multiple meter that can be used to test voltage.
    Could you please give more detailed instruction on have to test?
    I'm a newbie, I look at the schemes and know that they are standing for different parts but I don't know how to start the testing, I mean, I dont know where should I connect the pin to the test lead from the meter.
    Also, the red led is pwr and green one is act, they are both on, not flashing.
  • Robert Peter Oakes
    0 Robert Peter Oakes over 9 years ago
    What pin did you connect the 9V to, this will help in providing a more helpful answer
  • js1963on
    0 js1963on over 9 years ago in reply to Robert Peter Oakes
    I actually used a 9V battery pack with micro-usb port to power the pi, instead of 5 V.
    0 Robert Peter Oakes over 9 years ago in reply to js1963on
    Then this is the forst place to check as the input has protection and a zener
    See if the 5V on the right side is working when you are powering the device from a correct power adapter
  • js1963on
    This is very similar to the pi I have (mine is V1.1)
    Could you give more detailed instructions on how to check the right side?
    Thank you.
  • rew
    0 rew over 9 years ago
    The processor in the raspberry pi is a "smart" thing. It has a built-in DCDC converter to facilitate making a smartphone or other battery powered device from this processor. This means that the processor is directly connected to the input power. It is not the case that say a DCDC converter chip is connected to the input and that such a chip might have blown and shielded the important parts of the pi from the damaging voltages.
    Some chips have a "margin". i.e. the manufacturer tells you "no more than 12V", while in fact the chip will survive 15V. However modern chips, and especially chips that include fast processing stuff the margins are really small. The specs on the BCM2835 SOC (and its successors) say  5.5V, but I don't expect it to have any margin bigger than about half a volt. It'll break down permanently around 6V. :-(
  • js1963on
    0 js1963on over 9 years ago in reply to rew
    Thank you for the explanations.
    Do you mean it's permanently damaged by the 9V power?
  • rew
    0 rew over 9 years ago in reply to js1963on
    "Permanently damaged" wouldn't be very bad if the blown component was cheap and easy to replace.
    In this case the damaged component is likely the CPU. It is not very expensive (but impossible to obtain) and very difficult to replace.
  • js1963on
    ok. I guess I can not fix it if that's really the case. I would be careful next time then. Thank you.
