Raspberry Pi Forum Can you do multiple RCA video inputs into a raspery pi board and output to multiple screens?
  • Subscribers 707 subscribers
  • Views 2882 views
  • frontpage
iamjohn2407
iamjohn2407 over 9 years ago
I'm not fluent in what the capabilities of raspberry pi are but I've been thinking on a project that needs to be able to have 3 RCA video inputs and then be able to split it into 3 separate screens. The unit needs to be compact and that's part of why I had thought a raspberry pi setup might work for it. Is there any way to accomplish this?
Thanks for the help.
  • rew
    0 rew over 9 years ago
    The raspberry pi does not have ANY video input except for the camera interface. Also it cannot do three screens. Alas the raspberry pi is not a ready-made solution for your problem.
  • COMPACT
    0 COMPACT over 9 years ago
    You could combine a Raspberry Pi with a Video Crosspoint Matrix Switch such as the Vishay DG884.
  • Problemchild
    0 Problemchild over 9 years ago
    If you want all screens to display the same output then you'll need a composite video of HDMI splitter.
    If you are trying to have 3 separate displays then I believe you are out of luck here as the HDMI and Composite video are exclusive and only one works at a time.
    You could use 2  USB to video adaptors but these would be slow and expensive.
    A better solution here may be something like a miniITX with a separate Video card with the desired outputs.
  • COMPACT
    0 COMPACT over 9 years ago in reply to Problemchild
    Just buy some Composite Video to Digital video adapters and connect to a Dell P4317Q 43" 4K UHD IPS Multi Client Professional LED LCD Monitor.
    This monitor natively accepts 4 inputs.
