Raspberry Pi Forum Start Raspberry PI 3 at a specific time
  • Replies 11 replies
  • Answers 6 answers
  • Subscribers 707 subscribers
  • Views 5304 views
michaelr747
michaelr747 over 9 years ago
Am wanting to start raspberry pi 3 at a specified time e.g 08:00. Have looked at - SHIM RTC Realtime Clock https://www.element14.com/community/docs/DOC-68907?_ga=1.215302225.710711329.1484098904 but not sure if it can start PI. Have also looked at Witty Pi Realtime clock at $41.95 (looking for a cheaper option). Any suggestions would be greatly appreciated.
Michael
  • COMPACT
    0 COMPACT over 9 years ago
    See if you can use WOL (Wake On LAN)
    If not then try using and external power timer.
  • msimon
    0 msimon over 9 years ago
    SHIM RTC Realtime Clock will not do the job you want. SHIM RTC Realtime Clock (I miswrote it) Witty Pi Realtime will do but as you said it is expensive. Why do you want this? I mean RasPi consumes little power so you can turn off the peripheral devices and activate them when you need via software.
    There are some methods you can apply:
    If you have an uninterruptible power you can put Raspi in halt mode and activate it by lowering pin 5  (RPI safe mode - eLinux.org ). You can use an MCU with RTC and lower that pin whenever you want to activate it. You also need a software on Raspi to halt it.
    If you turn off Raspi remotely, you can use external power timer. However, I recommend using a microcontroller and relay so that you can communicate between MCU and Raspi. Therefore, you won't cut-off electricity without shut downing the Raspi.
    Mehmet
    0 mcb1 over 9 years ago
    Jon Watkins produced these.
    Sleepy Pi - Spell Foundry
    As i understand they were designed for just the type of thing you're looking for.
    0 shabaz over 9 years ago in reply to mcb1
    It is a nice, competent product for exactly this task. Jon sent one to me at the time, and it was clear he'd put a lot of effort into it.
    Very short blog post on the early version of it here:
    Sleepy Pi Overview
  • COMPACT
    0 COMPACT over 9 years ago in reply to mcb1
    It looks like overkill to me to have a computer to start another computer.
    0 mcb1 over 9 years ago in reply to COMPACT
    yes and no.
    There are many things the RPi just can't do, or doesn't do very well, and this also provides that functionality.
    Many systems have a watchdog and this is simply a more capable watchdog.
    Sadly I think it's pricing is making it less attractive, however it is a limited run, limited market and therefore quite justifiable.
    If it was in the $10 range then it could become more mainstream.
  • COMPACT
    The PI's two main chips the BMC2835 and LAN9512 both support low power modes and the LAN9512 supports WOL and Magic Packet.
    Therefore it should be possible to put both in a suitable power/sleep mode and wake up from a time triggered WOL/Magic Packet.
    sounds like you have a new blog to write ...
  • COMPACT
    I have the foggiest of minds.
    Oops! - that thought turned to rain, hit the ground and turned to mud.
    Reminiscent of my younger days in NZ.
  • michaelr747
    0 michaelr747 over 9 years ago in reply to msimon
    Hi Mehmet,
    Thank you very much for taking the time to assist with my query, your answer has helped enormously. At this stage have gone with an external power supply timer, am also (with help) currently looking at your other excellent suggestion - (However, I recommend using a microcontroller and relay so that you can communicate between MCU and Raspi. Therefore, you won't cut-off electricity without shut downing the Raspi)
    Am using the Raspberry Pi 3 for an in store shop monitor display, the mains power gets turned off everyday at 17:00, (back on 08:00) am using a daily command to shut Raspberry down at 16:45 and the external power timer to boot at 9:00. (even though it can boot at 08:00 there is a reason for starting it a 09:00)
    Again many many thanks for your input
    Regards
    Michael
