Raspberry Pi Forum rpi zero no activity
  • Subscribers 707 subscribers
  • Views 1004 views
will2055
will2055 over 9 years ago
I've been working on an autonomous rover with a raspberry pi zero. Recently I came into  a problem where I fashioned a usb to micro-usb dongle for a wireless keyboard/mouse. I believe that a wire crossed in while swinging around and shorted. My problem is that the Pi shutdown and anytime I connect a power source to it there is a power surge and the CPU gets hot. Is there a known issue with a short on the USB connector that affects the powering state of the Pi. Also when I say USB connector, I mean the connector that is labelled USB not PWR IN. This is both a question and a discussion, feedback is welcomed!
  • mconners
    0 mconners over 9 years ago
    A usb connector is going to provide power and ground for any devices that you connect. If you shorted them together, there is a very good possibility that you fried something. Is it a known issue on the Pi? I don't know, it's a known issue everywhere that if you short +5 to gnd you're gonna have issues.
    Mike
  • will2055
    0 will2055 over 9 years ago in reply to mconners
    The only reason I asked if it was a known issue is that although its not common some devices have safeguards in place. It is very likely the Pi Zero doesn't have those.
  • clem57
    0 clem57 over 9 years ago
    FYI, in working with my Pi zero, when I detach the PWR connector, the USB seems to continue to supply power although not enough to run reliably, This may be a bug, but I do not know.
  • mconners
    0 mconners over 9 years ago in reply to will2055
    Yeah, I was being a little flippant in my answer. I would expect that for cost purposes the zero is not the most robust device in the world.
    Mike
  • will2055
    five more minutes of engineering? possibly? But yes, for a $5 computer they won't do everything under the sun.
