Raspberry Pi Forum Help on PiFace Digital 2
  • Replies 7 replies
  • Subscribers 706 subscribers
  • Views 894 views
dcaccount
dcaccount over 9 years ago
I have found PiFace Digital 2 very interesting for a project of mine.
I would like to order it but I need to know what is the highest VAC it can switch 24/365 with no issue. Among the technical specifications I have found "Changeover relays, 20V 5A switching max" but this should be VDC.
Unfortunately on the PiFace web site I have found no way to contact developers.
Can anyone please help? How can I contact developers?
Thanks a lot,
daniele
  • Robert Peter Oakes
    0 Robert Peter Oakes over 9 years ago
    The relays themselves may be rated for that but the basic board design and clearances / stability with other parts will limit the recommended and approved voltage to about 30 or 40 volts only.. if you wish to power mains based equipment then I suggest using an intermediate relay in an approved mains enclosure / box / or a remote controlled switch like a SONOFF or something. this will be much safer.
  • dcaccount
    0 dcaccount over 9 years ago in reply to Robert Peter Oakes
    Hello Peter,
    thanks for replying.
    I just need to switch on and off a 24VAC that drives a relay that in turn powers on and off a water pump.
    So my question is if this board can stand and switch overtime a 24vac with no issues.
    As said, I have found no way to get in touch with developers.
    Thanks, Daniele
  • urkraft
    0 urkraft over 9 years ago
    Try this link:
    PiFace – About PiFace
    raymond
  • dcaccount
    0 dcaccount over 9 years ago in reply to urkraft
    I apologize but I can not find any contact in the link given.
    I just need to know if the two relays can support a 24 VAC and I do not know where to get this info.
    Thank, Daniele
  • urkraft
    0 urkraft over 9 years ago in reply to dcaccount
    If you click on the link i sent you and look at the bottom of the page you are redirected to you will see a "Contact" link. Clicking on that link will direct you to a page with contact information where you will find the following postal address:
    Contact
    Our Registered Office is: OpenLX SP Ltd, 145-157 St John Street, London, EC1V 4PW
    Registered Company number: 07613879
    Hope that is helpfull.
    raymond
  • dcaccount
    Thanks.
    I have found it.
    I would have liked an email addres. It looks strange they have neither email address nor contact formular
    0 Robert Peter Oakes over 9 years ago in reply to dcaccount
    the relays on the board will certainly support powering an external 24VAC relay (NOT 240VAC), and should be ok upto a couple of amps, but in this case, i doubt you will be near that load.
