Raspberry Pi Forum How do I get my RPi.GPIO to work?
  • Replies 8 replies
  • Answers 2 answers
  • Subscribers 709 subscribers
  • Views 2096 views
  • how do i get my gpio to work without syntax errors
gjelley
gjelley over 9 years ago
How do I get my GPIO to work without getting syntax errors in my program, it says it doesn't recognise GPIO.
  • mconners
    0 mconners over 9 years ago
    We need a bit more info than that.
    What program? Can you post the source code?
    Do you have the exact working of the errors?
    Mike
  • gjelley
    0 gjelley over 9 years ago in reply to mconners
    My program reads, "import RPi.GPIO as GPIO
    The error I get is that "GPIO unknown"
    Every time I use "GPIO" it gives me a syntax error.
    Regards
    Geoff
  • mconners
    0 mconners over 9 years ago in reply to gjelley
    OK Geoff. It appears you are using python
    what if you type
    sudo python <name of your program>
    Mike
  • volly
    0 volly over 9 years ago
    gjelley,
    Hi, it will not hurt to try the following few steps:
    Do a latest update:
    1.     sudo apt-get update
    Then install the Python Development toolkit that RPi.GPIO requires:
    2.     sudo apt-get install python-dev
    Then to install Rpi.GPIO itself type:
    3.     sudo apt-get install python-rpi.gpio
    You will probably be prompted to confirm by entering 'Y'.
    Then try your program again.....
    Regards.
    Yunus Vollenhoven
    South Africa
  • gjelley
    0 gjelley over 9 years ago in reply to volly
    What I get after .   "  sudo apt-get install python-dev"and                        " sudo apt-get install python-rpi gpio
    is "unable to locate package python.rpiand  "unable to locate package.gpio"
    Thank you for the ideas, any thing else?
    Regards,Geoff
  • michaelwylie
    0 michaelwylie over 9 years ago in reply to gjelley
    Is your Raspberry Pi connected to the internet? Are you running Raspbian?
  • volly
    0 volly over 9 years ago in reply to gjelley
    gjelley.
    Pardon my pudding....
    I omit the fact that you have to have an active connection to the internet to do these updates.....
    Yunus.
  • clem57
    0 clem57 over 9 years ago
    Looks like code from https://sourceforge.net/projects/raspberry-gpio-python/ It showed be downloaded and installed with deb command in Linux. But the description says:
    Note that the current release does not support SPI, I2C, 1-wire or serial functionality on the RPi yet. This is planned for the near future - watch this space!
    So beware!
    C
