Raspberry Pi Forum Did I just "brick" my Pi with PiDesktop?
  • Subscribers 706 subscribers
  • Views 667 views
  • frontpage
  • raspberry_pi_space
stone1343
stone1343 over 9 years ago
Hi, here' s what I did:
Pi 3 running the current Raspbian Jessie (2017-04-10) with Pi Desktop hardware
Added an SSD but didn't format it or anything
Installed pidesktop.deb
Ran ppp-hdclone. I guess the clone utility couldn't find my SSD because it wasn't formatted so neither button was enabled. When I closed the clone utility, there was something else running in the terminal with a warning about setting the OTP bit and I responded 'N' to this
Installed gparted and used it to format the SSD
Re-ran ppp-hdclone, the clone utility still couldn't find the SSD and again I responded 'N' to the terminal program.
Re-booted and now I get the four raspberry images (for the quad cores) and nothing else, the Pi seems to be completely dead.
Is there anything I can do now or is all that hardware now garbage?
Jeff
  • mconners
    0 mconners over 9 years ago
    Have you tried making a new sd card and starting over?
    That would be my first try. Usually installing software won't break hardware, it will just make it look that way.
    Mike
  • uscdadnyc
    0 uscdadnyc over 9 years ago
    JS wrote>>...Added an SSD but didn't format it or anything...
    USCDADNYC reply>>W/ OEM (original Equipment Manufacturer) SSD/HDD, I usually cable them up to a Windows PC FIRST. SATA if SATA, USB if this is a USB-Interfaced SSD/HDD. Goto Disk Management (in WIN10). There you will see your SSD/HDD W/O a Drive Designation. There are Options you select to make the SSD/HDD recognizable to WIN10. Shutdown the Windows PC. Then use the SSD/HDD on your RaspPi. I did this w/ two WD (Western Digital Pi-Drives) HDDs
    JS wrote>>...Installed pidesktop.deb. Ran ppp-hdclone...
    USCDADNYC Reply>> Not familar w/ both mentioned s/w packages. Sorry.
    JS wrote>>...Re-booted and now I get the four raspberry images (for the quad cores) and nothing else, the Pi seems to be completely dead...
    USCDADNYC>> IDT (I Don't Think) so. Try to re-loading the current Raspbian Jessie (2017-04-10) onto your uSDcard. Is your aim to have this SSD as a Storage Device on your RPi? BUT not to Boot off-of-it? (b/c IDK about doing that)
    USCDADNYC (NY NY USA)
    0 e14 Contributor over 9 years ago
    Your hardware is probably fine.  Re-install the latest Raspbian.
    I take it that your SSD is connected via USB.  What is your goal with the SSD?  Expanded storage or creating a bootable drive?
    If your goal is simply to expand storage, run `gparted` and format the drive.  I would recommend using the FAT32 format in case you would like to connect it to a Windows or Mac machine as well.
    If your goal is to create a bootable drive, then see my experience documented at Breathe New Life into that old Raspberry Pi 2 (ignore the title; the process is the same).
    Good luck.
