Raspberry Pi Forum pi desktop fdisk: cannot open /dev/sda: No such file or directory
  • Subscribers 702 subscribers
  • Views 3952 views
  • raspberry_pi_space
trlaing
trlaing over 9 years ago
Hi
I have just purchased a Pi Desktop, Raspberry Pi 3, official Raspberry Pi 2.5A power supply and a Sandisk SDSA5DK-032G 32GB mSata drive. I have followed the instructions in the Pi Desktop user guide to mount the mSata drive, but it is not working.
1. gparted does not see the drive (it only sees the default SD card).
2. "sudo fdisk /dev/sda" returns:
Changes will remain in memory only, until you decide to write them.
Be careful before using the write command.
You have new mail in /var/mail/pi
     "dir /dev | grep sda" returns
     fd     mmcblk0p2     sda     tty28     tty55     vcsa
3. I tried plugging the Pi Desktop USB port for the drive into my laptop and ran Disk Management, which said I had to initialize the disk but gave the error "The device is not ready" when trying to initialize it.
I have no other way to test the drive to see if it is working, but I just bought it and it is brand new. Any help would be much appreciated.
  • trlaing
    0 trlaing over 9 years ago
    I appear to have resolved the issue. I removed the mSata drive from the HAT and wiped the contacts and reinserted a bit harder, then started up the Pi and it is now recognised.
