Raspberry Pi Forum well a raspberry pi work for a laser engraver
  • Answers 3 answers
  • Subscribers 707 subscribers
  • Views 8955 views
bigman4021
bigman4021 over 9 years ago
well a raspberry pi 3 work on a laser engraver
  • the-dubster
    0 the-dubster over 9 years ago
    In a word - yes!
    A brief google search turned up these for you.
    https://www.raspberrypi.org/blog/home-made-cnc-laser-engraver/
    http://makezine.com/projects/engravr-a-pi-powered-laser-engraver/
    and
    https://www.thingiverse.com/thing:1026345
    The last gives you you a lot of info.
    Edit:
    (1)     The first two links reference (or point to) here - so only one is required really.
    (2)     Oops, last one is can run on a Raspberry Pi but control is using an Arduino Mega 2560 - which would make this little beaut very useful . . . .
              Essentially it uses GRBL (known as gerbil for fairly obvious reasons) - GRBL is used for 3D printers / Cutters / CNC Machines.
                        Kinda what you're after . . .
  • fvan
    0 fvan over 9 years ago
    Yes, I've successfully installed LaserWeb3 on a Raspberry Pi to control a cheap Chinese 2.5W laser engraver from banggood/gearbest.
  • bigman4021
    0 bigman4021 over 9 years ago
    well a beaglebone work for a laser engraver as well
  • the-dubster
    0 the-dubster over 9 years ago in reply to bigman4021
    Again, yes.
    There is a CNC cape available for use with LinuxCNC - more info from this very forum here.
    Essentially, RPi, Arduino, BB and probably any other Single Board Computer or Microcontoller has the capability of driving a Laser Engraver. If you can produce X/Y drawing commands to steppers and turn a laser on and off then you just need software to take your design and convert it to those drive signals.
    Do as I did, google it (I often end up linked to instructables or similar). Many have gone before with this project, no point reinventing the wheel here.
    I'd say your biggest challenge is going to be deciding on which software package you get on best with.
    Good luck.
  • Robert Peter Oakes
    0 Robert Peter Oakes over 9 years ago
    So technically the answer is yes but with caveats, the examples given above are for a wee little CNC / Laser engraver, almost every successful RPI based solution involves using a separate GRBL to Step/Direction controller, this can be abased on a UNO, MEGA, STM or other microcontroller on a a shield/Cape or connected via USB or serial.
    The PI is very good at providing the user interface (See OCTOPrint or Pronterface for example of 3D printer solutions... still GCODE) but the microcontroller is much better at the FAST step/direction pulse generation and timing required to move the steppers smoothly, there just not so good at translating a circle smoothly into step and direction for example, so the PI in the case of CNC machine is pacing the feed of GCode to the controller and also pre processing the GCode to simplify the arcs, circles and other complex moves into simpler sets the controller can easily deal with, this is the normal and in my opinion better approach.
