Raspberry Pi Forum Emberrasing basic question: How to start my Pi 3 B (with retropie) after shutting it down...
  • Replies 16 replies
  • Answers 5 answers
  • Subscribers 708 subscribers
  • Views 2824 views
  • problem
  • retro pi
  • ras pi 3
brabbelback
brabbelback over 9 years ago
As you already see in the title i have a question so basic, it's embarrassing.
After i booted retropie on my first brand new Pi, i installed some roms with a USB stick, played a couple of minutes mario and then shut the pi down through the option in the main menu. After this i turned the power source off (5V 2A).
And here is my problem: I can't get it back on. When i connect the power source again it starts blinking red and green, but my monitor doesn't do anything (and yes i checked if it is on C: ).
Please be kind as i have no experience at all with raspberry pi's!
Thank you in advance,
Brabbelback!
(Attached: a picture of my test-setup for my PIK3A table. The pi is connected with the controller (which works well) and a keyboard.)
  • michaelwylie
    0 michaelwylie over 9 years ago
    I've seen this before. It's power related. You can do a google search for just retropi won't boot after power down and you will see other people with the same problem. Hopefully the new power supply allows the system to shutdown correctly without corrupting the SD card.
  • ntewinkel
    0 ntewinkel over 9 years ago in reply to michaelwylie
    I've basically come to the conclusion that cell phone and tablet chargers don't play nice with Raspberry Pi, no matter what their ratings are - the RPi really does need a dedicated proper power supply to run it reliably.
  • brabbelback
    0 brabbelback over 9 years ago in reply to ntewinkel
    Ok, if this is the case i will hopefully be able to solve this problem tomorrow! Thanks a lot!
  • ninjatrent
    0 ninjatrent over 8 years ago
    The boot time for RetroPie can take a few minutes at times. This might be part of the issue. Or the image on SD might have been corrupted.
  • brabbelback
    0 brabbelback over 8 years ago in reply to ninjatrent
    The SD card was corrupted because the power supply was too low!
  • ninjatrent
    0 ninjatrent over 8 years ago in reply to brabbelback
    That could do it. The SD card should still be okay to use again after a fresh image is installed. Gparted is a good for checking the contents of drives. What size and type of SD card are you using?
