Raspberry Pi Forum Emberrasing basic question: How to start my Pi 3 B (with retropie) after shutting it down...
  • Replies 16 replies
  • Answers 5 answers
  • Subscribers 708 subscribers
  • Views 2815 views
  • problem
  • retro pi
  • ras pi 3
brabbelback
brabbelback over 9 years ago
As you already see in the title i have a question so basic, it's embarrassing.
After i booted retropie on my first brand new Pi, i installed some roms with a USB stick, played a couple of minutes mario and then shut the pi down through the option in the main menu. After this i turned the power source off (5V 2A).
And here is my problem: I can't get it back on. When i connect the power source again it starts blinking red and green, but my monitor doesn't do anything (and yes i checked if it is on C: ).
Please be kind as i have no experience at all with raspberry pi's!
Thank you in advance,
Brabbelback!
(Attached: a picture of my test-setup for my PIK3A table. The pi is connected with the controller (which works well) and a keyboard.)
    0 balearicdynamics over 9 years ago
    Don't worry are other the thing that can be embarassing... Just a first suggestion: Pi3 expect a power supply 2.5A and not 2A Maybe that while installing and setting up you have added the parts one by one and the power was sufficient. Now after the entire setup has been done with only 2A Pi may have serious problems to restart. Maybe not, but in my opinion this is the first thing to consider: try if possible to remove - also temporary while booting - something not essential, like the USB stick if you have left it inside and see if the system start again.
    If not, leave only the monitor connected and try booting adding progressively all the connections and see if something generate the boot stop.
    If possible also describe what you see while booting: after powering red led should be on then green led will start blinking while boot proceed, if I am not wrong.
    Enrico
  • michaelwylie
    0 michaelwylie over 9 years ago
    Reinstall the image on the card (format first) and try to boot it. I suspect there is an issue corrupting the SD card.
  • brabbelback
    0 brabbelback over 9 years ago in reply to michaelwylie
    I did this and it worked fine! When i rewrote the image on the sd card and installed it again on the pi everything worked fine. Until i wanted to start it again! nothing happened, like the first time.
    0 e14 Contributor over 9 years ago
    It sounds silly but disconnect the power, remove the sdcard then put it back in and apply power again. Give it a try, if it works then you may have the problem re-occur. It happens with somd brands of sdcard but not others.
    If it doesnt work try a re-install like michael suggests above
  • brabbelback
    0 brabbelback over 9 years ago in reply to balearicdynamics
    The new power cable with 5V 2.5A arrives tomorrow! I tried only with the monitor and this is what happened:
    First only the red LED blinked a few times, then the green one joined and also blinked a few times. After this for a few seconds none of them blinked until the green one started blinking in almost rhythmically. (edit: after a few minutes the green led stopped blinking and only the red is constantly on now.)
  • brabbelback
    0 brabbelback over 9 years ago in reply to e14 Contributor
    I already tried all the "turn it off and on again" methods i could think of /: nothing worked....
    0 e14 Contributor over 9 years ago in reply to brabbelback
    did you remove the sdcard and plug it back in too (some brands seem to struggle possibly due to them not powering down/up cleanly)
  • brabbelback
    Yes i did! I did it while the pi was on, while the pi was off and i even rewrote the image on the SD card! When i inserted it with a "new" image it booted and installed retropi correctly!
  • beacon_dave
    0 beacon_dave over 9 years ago in reply to brabbelback
    Perhaps take a look at this trouble-shooting Wiki
    R-Pi Troubleshooting - eLinux.org
    As you can see, the flashing red power LED usually suggests power related issues. The new 2.5A PSU may resolve this.
  • brabbelback
    0 brabbelback over 9 years ago in reply to beacon_dave
    Thanks! If it is a power related issue i will hopefully be able to solve this with the new cable tomorrow!
