Raspberry Pi Forum raspberry pi modbus slave
  • Replies 10 replies
  • Answers 5 answers
  • Subscribers 707 subscribers
  • Views 4924 views
  • frontpage
  • modbus rtu
  • raspberrypi
patil.sunny9999
patil.sunny9999 over 8 years ago
Hello There,
Anyone Please help me with Modbus. I am completely new with modbus
I am Stuck here. I have to make my Raspberry pi as slave device which will response to modscan32 software.
Currently i am using libmodbus stack, but it constantly popping the error that "modbus.h, no such file or directory."
I am using RX TX gpio pins for Data Transmitting and receiving along with RS232 circuitry.
Please suggest me if any alternative modbus libraries available for raspberry pi.
thank you.
  • luislabmo
    0 luislabmo over 8 years ago
    Hello patil.sunny9999, try these instructions
    https://github.com/stephane/libmodbus/wiki/Libmodbus-on-Raspberry-pi
    Good luck!
  • patil.sunny9999
    0 patil.sunny9999 over 8 years ago
    dhruvvyas90 i am using your libmodbus-master stack for RPi test. as i compile test.c from Rpi-test folder it gives me following error
    " test.c:10:20: fatal error: modbus.h: No such file or directory "
    Please help me out I am beginner with linux and raspberry pi.
    Thank you in advance
  • rew
    0 rew over 8 years ago in reply to patil.sunny9999
    That means that the compilation requires a file called "modbus.h". That would be something that comes with a modbus library. So you type:
    apt-cache search modbus
    This looks for packages wtih "modubs" in the name.
    You will see "libmodubs" and libnmodubs-dev. ThThe first one is the run-time, that people running things that use the lib need, the second one will have development files that you need.
    Sorry for the typos.
    Element14 has changed the forum somehow to scroll to the top of the topic for every character that I type.
    Interesting way to allow peopel eto eneter stuff into a form....
  • patil.sunny9999
    dhruvvyas90 rew As i Come out of one Error, I messed with Another one. please suggest me any solution for below error.
    pi@raspberrypi:~/libmodbus-master/rpi-test $ gcc test.c -o test `pkg-config --libs --cflags libmodbus`
    test.c: In function ‘main’:
    test.c:45:5: warning: implicit declaration of function ‘modbus_enable_rpi’ [-Wimplicit-function-declaration]
         modbus_enable_rpi(ctx,TRUE);
    test.c:46:5: warning: implicit declaration of function ‘modbus_configure_rpi_bcm_pin’ [-Wimplicit-function-declaration]
         modbus_configure_rpi_bcm_pin(ctx,BCM_PIN_NO);
    test.c:47:5: warning: implicit declaration of function ‘modbus_rpi_pin_export_direction’ [-Wimplicit-function-declaration]
         modbus_rpi_pin_export_direction(ctx);
    test.c:62:5: warning: implicit declaration of function ‘modbus_rpi_pin_unexport_direction’ [-Wimplicit-function-declaration]
         modbus_rpi_pin_unexport_direction(ctx);
    /tmp/ccorPCkV.o: In function `main':
    test.c:(.text+0xc8): undefined reference to `modbus_enable_rpi'
    test.c:(.text+0xd4): undefined reference to `modbus_configure_rpi_bcm_pin'
    test.c:(.text+0xdc): undefined reference to `modbus_rpi_pin_export_direction'
    test.c:(.text+0x19c): undefined reference to `modbus_rpi_pin_unexport_direction'
    collect2: error: ld returned 1 exit status
  • patil.sunny9999
    rew Robert Peter Oakes The specified item was not found. @
    hello there.
    can any one please help me with this.
    SerialException: [Errno 2] could not open port dev/ttyAMA0: [Errno 2] No such file or directory: 'dev/ttyAMA0'
    i search alot but cannot find the proper solution for it.
    i am using Raspberry pi 3.
    thank you in advance
  • rew
    There are two possibilities. First, there is a / missing in /dev/ttyAMA0 .
    Second, you may have a raspberry pi 3, where ttyAMA is used to communicate with the bluetooth. I'm not sure what the best option would be, but the first thing to try is to  activate the disable-bt overlay:  Add to  /.boot/config.txt:
    # Disable internal BT
    dtoverlay=pi3-disable-bt
    P.S. The new "scroll to top of thread" that happens when you press a key while editing a post is highly annoying. I had to finish typing this blind.
  • patil.sunny9999
    rew
    i have already disabled the bluetooth, and my serial communication is working properly too.
    as i run my pymodbus server program it shows me that error
    the complete error it show is as below.
    INFO:pymodbus.server.async:Starting Modbus Serial Server on dev/ttyAMA0
    Traceback (most recent call last):
      File "/home/pi/pymodbus-master/examples/common/callback-server.py", line 134, in <module>
        StartSerialServer(context, identity=identity, port = 'dev/ttyAMA0')
      File "/home/pi/.local/lib/python2.7/site-packages/pymodbus/server/async.py", line 272, in StartSerialServer
        SerialPort(protocol, port, reactor, baudrate)
      File "/home/pi/.local/lib/python2.7/site-packages/twisted/internet/_posixserialport.py", line 37, in __init__
        xonxoff=xonxoff, rtscts=rtscts)
      File "/home/pi/.local/lib/python2.7/site-packages/serial/serialutil.py", line 240, in __init__
        self.open()
      File "/home/pi/.local/lib/python2.7/site-packages/serial/serialposix.py", line 268, in open
        raise SerialException(msg.errno, "could not open port {}: {}".format(self._port, msg))
  • rew
    May I refer you to my post above. It gives you the answer.
  • Robert Peter Oakes
    0 Robert Peter Oakes over 8 years ago in reply to patil.sunny9999
    Have you enabled it through raspi-config and possibly given yourself permissions if your not running as root ?
    Also look in /dev you should see a file called ttyAMA
    hope this helps
  • rew
    0 rew over 8 years ago in reply to Robert Peter Oakes
    It will be in /dev, but not in dev. The configured device name is wrong. Simple as that. Now we have the full error message it is clear as crystal: There is a typo in the confgured devicename. without the error message we were left guessing if there was a typo in the transcript from the error message, or if there was something else going on. With the full error message, there is a very small chance that he typed it all by hand, and the same device-name-with-typo is mentioned twice in the error message. There is no doubt about it.
    Peter, the error message is: "no such file or directory". So it is NOT a permissions problem. Apparently people have trouble with "it could be this, or it could be that". Then when it turns out it is not "this", then the "that" option should be investigated. By suggesting a permissions problem, that cannot be the cause, you risk patil going off on a wild goose chase again.
