Raspberry Pi Forum Raspberry pi project
  • Replies 7 replies
  • Answers 5 answers
  • Subscribers 707 subscribers
  • Views 1059 views
vasi_t
vasi_t over 8 years ago
Hi guys, I have a problem and I hope someone is willing to help me. I want to do a fun project with my raspberry pi zero. I want to do a portable mini ''console''. I have almost everything I need except the case (because I dont have a 3D Printer) and I want to ad to this ''console'' my own Controller. It's pretty easy. 4 buttons, 2 triggers, 1 Dpad and a Joystick. But I have 0 experience with diy Controller and that kind of stuff and I would need help. Is there a board that can signals from buttons and transform it into a USB signal  or can I put tha signals direct in the Raspberry pi (sorry if its not grammatical correct what I wrote). I would really apreciate every help I can get.
  • gadget.iom
    0 gadget.iom over 8 years ago
    It might've been worth having a search on the forums before posting this question. The following article might be a good starting point:
    PIK3A: The Raspberry Pi 3 IKEA Retro Gaming Table
    Paul
  • vasi_t
    0 vasi_t over 8 years ago in reply to gadget.iom
    Thank you
  • beacon_dave
    0 beacon_dave over 8 years ago
    You may be interested in this U-HID board:
    Uhid :
    However the likes of the Arduino Leonardo is often used for this purpose as per the PIK3A project mentioned previously.
    The ATmega32U4 microcontrollers have built in USB support so Arduinos using them offer this sort of functionality e.g.
    https://store.arduino.cc/usa/arduino-leonardo-with-headers
    https://store.arduino.cc/usa/arduino-micro
    Keyboard functions
    https://www.arduino.cc/reference/en/language/functions/usb/keyboard/
    Mouse functions
    https://www.arduino.cc/reference/en/language/functions/usb/mouse/
  • vasi_t
    0 vasi_t over 8 years ago in reply to beacon_dave
    Thank you so much.
    Only one Question. are both Arduino boards the same only the size is different? Because I need a small one so I would chose the second.
  • mconners
    0 mconners over 8 years ago in reply to vasi_t
    They are different sizes. I used one of these
    https://www.amazon.com/gp/product/B012FOV17O/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
    Which is quite small.
    Mike
  • gadget.iom
    0 gadget.iom over 8 years ago in reply to vasi_t
    Either should work fine for your needs.
    You might also want to look at something like the TeensyLC. It should do keyboard emulation as well. Depending on where you are based it might work out a little cheaper too.
    https://www.pjrc.com/teensy/teensyLC.html
    There is a guide to connecting the device together with some sample code:
    https://www.pjrc.com/teensy/td_keyboard.html
  • beacon_dave
    0 beacon_dave over 8 years ago in reply to vasi_t
    There are some minor differences apart from size, however I don't think there is anything that will cause you problems.
    Leonardo schematic:
    https://www.arduino.cc/en/uploads/Main/arduino-leonardo-schematic_3b.pdf
    Micro schematic:
    https://www.arduino.cc/en/uploads/Main/arduino-micro-schematic.pdf
    Adafruit do some small ATmega32u4 based boards as well e.g.:
    https://learn.adafruit.com/atmega32u4-breakout/intro
    however if you are just starting out, then the Arduino Micro may be a safer bet.
